Never mind guys. I've just realised that alot of the V4 shoes dont conform very well to the standard non-weight mapped V4 as well.
I suppose it is just a case a fiddling with dials :o)
Regards
Marv
i7 5930K 3.60Ghz | ASUS X99-S Motherboard | Crucial Ballistix Sport 32GB DDR4 2400MHz RAM | NVIDIA TitanX | Antec 1000w Power supply | Windows 10 x64 Home
There are some badly rigged shoes out there, and Outfitter will find them...
"Oh - the manual says that? I have never read the manual - this must be why."After you convet them, you will also have to enlarge some of the the sphere zones.
Transfering the toe and foot joints info from the character to the shoe is only part of what needs done if any part of the shoe extends outside of the characters joint info.
And just about every shoe does extend past that. Like WandW said, some are not rigged so well, but that is usually fairly easy to fix as well.
Some things are easy to explain, other things are not........ <- Store -> <-Freebies->
Quote - Hi Guys,
Once you've conformed the V4 shoes to WM make sure you then copy the: copy joint zones from..... (under the Figure menu) and this should make them fit better.
If you do this it will almost always mess up the falloff zones of the shoe's toe actors (unless they are very form fitting, such as sox) and they will need to be adjusted, as shvrdavid notes. ..
"Oh - the manual says that? I have never read the manual - this must be why."This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hi guys
Is there a solution to converting V4 shoes to V4 weight mapped (WM) shoes?
I have tried outfitter and wardrobe wizard (WW) and neither allow me to conform to the figure properly.
With WW I deselected the toes before converting as I believe you are supposed to do and used the modified figure .cr2 the WM's were being copied from when asked.
I have tried selecting match end points and copy joints from figure as well.
I'm a bit stumped now LOL
Is this just something I have to live with or is there a fix?
Thanks Guys
Marv
