Sat, Jan 11, 11:51 AM CST
Subject: Morph Master 1.01
CodeTwister ( ) posted Tue, 11 September 2001 at 12:20 PM ยท edited Sat, 11 January 2025 at 8:52 AM
With the version 1.01 you can setup Morph Master to use OpenGL (the standard library that he uses to render the images) in software mode. So if you have an out of date video card or have troubles with the drivers you can switch Morph Master to avoid the use of the hardware acceleration. Morph Master is highly optimized so the loss in performances using the software mode are minimal. The mode is changed through an external program accessible with start menu "OpenGL mode setup". After you have changed the mode you must restart Morph Master for new setting to take effect. Have fun CodeTwister
JeffH ( ) posted Tue, 11 September 2001 at 12:24 PM
You forgot your link.
CodeTwister ( ) posted Tue, 11 September 2001 at 12:39 PM
Attached Link: http://www.codetwister.com/
Morph Master 1.01 is posted in Free Stuff/Utilities but it can be downloaded also from my site http://www.codetwister.com/
jamball77 ( ) posted Thu, 13 September 2001 at 11:08 PM
thanks for putting so much into this wonderful utility. I'm making more and more of my Lightwave stuff into Poser stuff and your utility helps. thanks.
