Tue, Jan 7, 12:27 AM CST
Subject: Materials: 3D nodes and specular
Believable3D ( ) posted Mon, 31 December 2012 at 1:26 AM · edited Tue, 07 January 2025 at 12:27 AM
I'm experimenting with using Fractal_Sum in Displacement to create a brush cut type hair. Which works okay, except I haven't figured out how to get specular. I guess it doesn't work on node-based displacement? or is there a workaround? I've tried various ways of connecting a Specular to the Fractal_Sum (from the Alternate_Diffuse channel), but no luck....
______________
Anthanasius ( ) posted Mon, 31 December 2012 at 7:50 AM
Without shader it's difficult to help you ;)
Génération mobiles Le Forum / Le Site
Believable3D ( ) posted Mon, 07 January 2013 at 10:59 AM
Well, maybe you can't help, anyway, since you don't say whether it's possible to generate specular on node-based displacement. If it's possible, then my non-working shader is the wrong thing to post. :)
______________
templargfx ( ) posted Mon, 07 January 2013 at 4:43 PM
I do not beleive this is possible.  the specular seems to only apply to the original surface sub-poly and not the sides of the displaced sub-poly.
TemplarGFX
3D Hobbyist since 1996
I use poser native units
167 Car Materials for Poser
