Mon, Dec 23, 1:47 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Add lights to a scene lt2-not replace via script
grichter ( ) posted Sat, 08 December 2012 at 7:45 PM · edited Mon, 23 December 2024 at 1:41 AM
You can add a light set (lt2) a scene and it acts like a normal light set and replaces all lights with the new light set with this simple code...
import os
import poser
scene = poser.Scene()
def loadLibraryFile():
   path = "/runtime/Libraries/Collections/My Lights/Revised.lt2"
   try:
        scene.LoadLibraryLight(path)
   except:
      pass
loadLibraryFile()
But if you want to say add a pre-defined spot where you have set the shadows, etc and location of where it loads, using the above method it over writes all the lights instead of just adding one more spot to the scene.
Is there a simple scene method to add the lights vs apply the lights like the single and double check boxes in the poser library pallet?
I looked thru the methods manual and can't locate something that looks like it does the trick and I need to know if I skipped over something by not understanding its function.
Yes I know you can write a script to create a light, but it would be much easier if I could use the scene method up at the top and bring in a pre-made light set saved off the the library.
Thanks in advance for any help or suggestions
Gary
Gary
markschum ( ) posted Sat, 08 December 2012 at 10:02 PM
The only way I know is to create the light and then apply a pose to position it etc.
You could possibly import a pz3 file of lights, but I dont see a command to do that.
semidieu ( ) posted Mon, 10 December 2012 at 2:32 PM
Adding a light isn't that easy... I made it possible by saving the current light settings in a temporary file, merge the new ligh lt2 file with the temporary version (there are things to take care of...) and then load the merged file...
If someone has a better verison - let me know!
grichter ( ) posted Mon, 10 December 2012 at 3:48 PM
Thanks guys. Appreciate the feedback...back to the drawing board...
semidieu, what do you mean adding a light is not easy...Have you seen the Shaderworks Light script package at RDNA. It has a create light feature! :biggrin:
Gary
semidieu ( ) posted Mon, 10 December 2012 at 4:14 PM
Yes I saw it :) Well... I did it :) And it's using this feature :)
markschum ( ) posted Tue, 11 December 2012 at 1:10 AM
I wrote a script that merges two sets of lights but I was never sure it worked. I will send it if you can pm me an email address.
lesbentley ( ) posted Mon, 07 January 2013 at 5:24 PM
I can't speak on the Python aspect of this issue, but as to the Poser library file aspect...
In P8 and up, you have two ways of loading a light set from the library, Replace (single tick), or Add (double tick). Using Add, you can add as many instances of the light(s) as you like. I don't know if there is any way of choosing between Add and Replace if you are loading the lt2 via Python.
In P8 and up, if you load a light from a pp2, each new instance will have the name incremented by a number, so you can load any amount of new instances of the light from the same pp2 file (and without affecting existing lights). The pp2 should be in the appropriate folder, I think just renaming an lt2 to pp2 and leaving it in the Light folder may cause problems. It works the same for loading lights from a cr2, but again, a cr2 has both Add and Replace loading modes, so it may not work via Python. A pp2 only has the Add loading mode, so I assume it should work OK via python.
If I remember correctly, the above method does not work in P6, in that version, any method of loading a light will overwrite an existing light of the same name. I don't know how it works in P7, as I never owned that version.
On the separate issue of loading a new light set turning off the pre-existing lights in the scene, I think loading the lights via a cr2 or pp2 overcomes that problem in any Poser version.
When I used P4-P6 I often parented lights to a figure (one with only a BODY actor), so that I could load the light set without turning off other lights in the scene.
