Mon, Dec 2, 9:42 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:09 am)
Subject: Trying to add Spots node to displacement - 3 questions
parrotdolphin ( ) posted Thu, 17 January 2013 at 9:30 PM · edited Mon, 02 December 2024 at 6:56 AM
I am trying to set a displacement amount and add a Spots node to the displacement. My script works to connect the Spots node to the displacement but I am not sure how to set the displacement amount or the Base_Color on the Spots node, or to tell it whether the Noise_Type is Improved or Original on the Spots node.
Does someone know? I would be grateful.
Thanks,
Janet
Here is the script:
import poser
def addDISP(mat):
    scene = poser.Scene()
    tree = mat.ShaderTree()
    root = tree.Node(0)
    if (root.Type() != poser.kNodeTypeCodePOSERSURFACE):
        print "Select a material first"
        return
    displacein = root.InputByInternalName("Displacement")
    dispin = displacein.InNode()
    #SetDisplacment(0.06)         #trying to set the amount of displacement
    furry = tree.CreateNode(poser.kNodeTypeCodeSPOTS)
    #furry.Input(0).Set???(0,0,0) #trying to set the Base_Color on Spots node to black
    furry.Input(2).SetFloat(0.01)
    furry.Input(3).SetFloat(0.5)
    furry.Input(4).SetFloat(0.5)
    #furry,Input(6).Set???(1)     #trying to set Noise_Type to Improved
    furry.ConnectToInput(displacein)
    furry.SetLocation(400, 400)
    tree.UpdatePreview()
mat = poser.Scene().CurrentMaterial()
addDISP(mat)
parrotdolphin ( ) posted Thu, 17 January 2013 at 10:18 PM
I think I got it figured out now. Here's the working script in case anyone is interested. It's to make a material furry.
import poser
def addDISP(mat):
    root = tree.Node(0)
        return
    displacein.SetFloat(0.7)       #sets the amount of displacement
    furry.Input(0).SetColor(0,0,0) #sets the Base_Color on Spots node to black
    furry.Input(2).SetFloat(0.01)  #sets spot size
    furry.Input(6).SetFloat(2)     #sets Noise_Type to Improved
addDISP(mat)
markschum ( ) posted Thu, 17 January 2013 at 11:21 PM
:thumbupboth:
pitklad ( ) posted Wed, 23 January 2013 at 2:01 AM
Cool! I should give this a chance, thanks!
My FreeStuff
