Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 12:55 am)
Yes , you seem to have a fair grasp of it. Just name your textures so you know what they apply to. I tend to put midified textures in the same folder as the originals, so all textures for that product are in the same place.
read the manual os also good advice. Its available off the help menu and was a pdf file in the program folder.
Quote - Yes , you seem to have a fair grasp of it. Just name your textures so you know what they apply to. I tend to put midified textures in the same folder as the originals, so all textures for that product are in the same place.
Yep, I do the same and keep the new/modified texture in the same folder with the name changed to reflect the difference from the original. If I have created the new texture using layers I even keep a copy of this in the same folder along with the file I use in Poser. That way if you want to make any changes you can use the layered file and save without degrading the image.
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 - Ryzen 9 5900HX, with 64 gig ram and 3 TB storage, mini PC with final rendering done on normal sized desktop using an AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU . The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
I have some basic texturing tutorials in Acrobat PDF format on my site (starting at "Texturing for Beginners" - just scroll down a little). Heidi wrote them some time ago, so you won't find anything about the material room, but the basics of using a template to produce a map haven't changed.
piccolo_909,
Try stitch-witch, it is not out of reach for the beginner and will give you an edge.
http://www.daz3d.com/stitch-witch-1
http://forumarchive.daz3d.com/viewtopic.php?t=97238&postdays=0&postorder=asc&start=0
Sveva's Texturing for Beginners is a great place to start.
http://www.renderosity.com/mod/bcs/sv-texturing-for-beginners/95737
I started playing around with a small prop that comes with some nice diffuse/specular/displacement maps, and i noticed that the template was also included. I thought this would be a good time to start learning some texturing. Two things i'm going to try out is:
Modifying an existing texture
Creating a completely new texture from scratch
I have a decent understanding of the material room, and how different kinds of maps work. I also know that the template is used to make your own textures, and you have to paint a 3d picture in 2d space. Right now i'm only concerned with the outside diffuse texture map.
I'll start with modifying an existing texture. The first problem is i'm not sure how i'd get it working. Most models you go to the pose or material section of your library, click a button, and apply the textures/shaders that way. So if i wanted to change just the diffuse texture, what's the best way to go about doing it? I was thinking that i need to make a copy of the existing texture, make changes to it in photoshop, then create a separate folder to store all my changed textures. Then when i need to use it, i load up all the original textures for the prop (so i can get the specular and all the other maps), then change the diffuse image map in the material room to the modified one. Is that how i would modify an existing texture and use it?
Next is creating a texture from scratch. How do i use the template? Do i just load it up in photoshop and paint my texture within the lines? What do i need to do to create a texture from scratch?
