I'm not sure you can do that, nor should it be necessary. If the paths are set correctly - ie relative - Poser will read from whichever Runtime is active. AFAIK, it can't read from an inactive Runtime at all.
Do you mean to change the paths to the external runtimes in the Library? It should be fine if you simply add the runtimes you moved over to the Library as external runtimes.
If you happened to copy over the libraryPrefs.xml file you could also possibly change the paths in that file; you didn't mention what version of Poser you are running...
"Oh - the manual says that? I have never read the manual - this must be why."This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Due to comp going down and until can afford redo another computer, have copied runtimes poser etc to older computer.
Apart from notepad read pz3 file, I need to no of another program where I can read file then no where character, skin and all other props were, in which runtime.
As drive letters will be diff for runtimes..
