Mon, Nov 25, 3:31 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: python interface options for Poser 8,9, 2012
markschum ( ) posted Mon, 28 January 2013 at 7:45 PM · edited Mon, 25 November 2024 at 1:42 PM
I have a few scripts to do things like extract inj pose files from a cr2.
To avoid editing the script (which I do) I need to add a user interface.
I have used TKINTER for a few things.
Does tkinter still work after Poser 7 (which is what I have) or do I need to use the wx stuff ?   xml ?
I may be able to get Poser 9 if that will allow me to code for Pro 2012 .
Pret-a-3D ( ) posted Mon, 28 January 2013 at 7:51 PM
Keep in mind that Tkinter is a dead-end. It doesn't work on Poser 64 bit.
Cheers.
Paolo
https://www.preta3d.com
FB: https://www.facebook.com/RealityPlugIn
Tw: @preta3d
G+: https://plus.google.com/106625816153304163119
The Reality Gallery: https://reality-plug-in.deviantart.com
gishzida ( ) posted Mon, 28 January 2013 at 8:42 PM
Quote - Keep in mind that Tkinter is a dead-end. It doesn't work on Poser 64 bit.
Cheers.
If it does not work in x64 then why is it in my Poser Pro 2012 for Windows python dlls folder? or are you referring to Tkinter not working in OSX?
Pret-a-3D ( ) posted Mon, 28 January 2013 at 9:17 PM
PhilC ( ) posted Tue, 29 January 2013 at 1:23 AM
Strongly suggest that you use wxPython rather than tkinter
