Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
Load up Poser, go into your main work area and press your right mouse button.
Does it say OpenGL or SreeD?
Change it to the one it currently isn't. Eg - if OpenGL, change to SreeD.
Do a render and see if that cures it.
All the best.
LROG
Who honors those we love for the very life we live?, Who sends monsters to kill us?, and at the same time sings that we will never die., Who teaches us whats real?, and how to laugh at lies?, Who decides why we live and what we'll die to defend?, Who chains us?, and Who holds the key that can set us free... It's You!, You have all the weapons you need., Now Fight!
Without more information, we are shooting into the "dark".
You may also get a black render if your camera is in a wall or object. Sometimes, preview shows the scene, but rendering goes black. If this is the problem, move the camera closer and try again.
lmk
Probably edited for spelling, grammer, punctuation, or typos.
Hi
I can open Poser with just Andy in the frame.
Not make any changes to the scene.
Hit Render and I get a black screen, it doesn't have to do with content.
I can use Sketch Style and I get a render.
But if I use Firefly I get a black screen.
I'm using Open GL, and I reset all the Firefly settings to default
I don't have a clue what's going on, I've never run into this before.
It was working fine last week.
Mike
If you shoot a mime, do you need a silencer?
can you show us a screenshot of your render settings?
at one point i was getting black renders cause i inadvertently changed the render output settings. there is a drop down arrow on the bottom right of the manual render settings window. has to do with psd layers.
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
Attached Link: http://s1238.beta.photobucket.com/user/nohjekim/media/PoserCapture_zpsaaa20d92.jpg.html
HiHere it is on top of a view of the render screen after Andy has been rendered.
just 2 thoughts from someone who has no business putting her 2 cents worth in. One, try and see what happens when you turn on raytracing in your render settings. Two, check your lights, are they on and don't have both the diffuse and the specular set to black. I know this is kind of simple but sometime we over look this simple trying to fide the diffucult problem.
Hi Everyone!
The problem is fixed.
After going through the General preferences I saw that Render was set to be a separate process (I don't really know what that means) but when I unchecked the check box it started working again.
Maybe someone can tell me when you would use that option?
I probably did this myself I know I set the number of threads to 32, and I may have clicked this just to see what happens.
Now I know. LOL
Thanks for the suggestions everybody.
Mike
they may have set FFRender as separate process to better use physical RAM, but try threads as 2X cores. in current version(s), it may be necessary to shut down and restart poser if black screen during FFRender. I don't know if this is an OS X issue with poor memory management, or if it's a cross-platform issue.
I've always used Render as a Separate Process since Poser 7 without issue, but I'm using Windows.
Just a thought; could it be some sort of permissions issue for FFrender?
"Oh - the manual says that? I have never read the manual - this must be why."Attached Link: Here is my Settings window.
HiI'm running Windows 8, and I guess I've always run in what ever the default setting is.
But I tried turning it back to Render as a Separate Process and it quit working again.
So that's definitely what's causing the problem.
I have 32 Gigs of ram, and a new version i7 processer running at 3.6 Ghz, and a nVidia Geforce 680 vidio card. so it's not a matter of computer performance.
I would like to ask what, Run in Background thread, does, and which way it should be set and for what reason?
Mike
After you install Poser and run it for the first time, Windows will prompt you to allow access through the firewall for the program. In case of Poser it will ask for Poser.exe or PoserPro.exe. If you set external process On and you start the first render after that, it will prompt you for FFRender.exe or FFRender64.exe. If you deny access, it will not run.
For whatever reason (problems during install, accidentally saying No, or whatever), Windows thinks FFRender is not allowed to run (or access the network) and it will stop, leaving you with a black render
How to check this or change it: Go to the control panel, select Windows Firewall, then select "Allow an app or feature through the firewall". There you should add FFRender or change the permission to allow it to go through the firewall (private network)
If that was already correct,. it may be an issue with another firewall or AV product
Hi
I recently started getting a black screen when I do a render using Firefly Renderer.
Preview works fine, Sketch works fine but not Firefly.
It seems to go through the normal process, it shows what it's doing but when I get done the screen is just a blank black screen.
I may have messed up some setting messing around with it but I can't figure out what.
I thought I ask here before I reinstall and see if anyone has any ideas.
Mike
