Mon, Nov 25, 5:23 PM CST
Subject: Adding Magical Glow To a Character
3doutlaw ( ) posted Wed, 06 February 2013 at 3:25 PM
Postwork.
Render your character sans background...select background area in gimp/pain.net/photoshop...invert selection (basically selecting your character)...fill glow color...blur as desired...save on layer under character.  (or blend, or etc..)
Saxon3d ( ) posted Wed, 06 February 2013 at 3:29 PM
I suppose you could achieve similar by arranging a series of point or spotlights behind the character, i've never tried it, but it should be possible
markschum ( ) posted Wed, 06 February 2013 at 3:34 PM
I think a lot of effects are most easily done in a paint program like Gimp or Photoshop or any other you like, preferably with layers.
You can make a texture and apply it to a prop square, prop ball (elongate with scale y) and make them partially transparent.You can turn up ambiant or use backlighting and some fog.
I am sure others will post better ways.
hborre ( ) posted Wed, 06 February 2013 at 6:53 PM
Online Now!
Getting that effect right in Poser may take much more time than taking the image into a 3rd party paint program and applying it there.  A rim lighting would not give you the same effect unless you can figure a way of applying a soft diffuse layer between the model and camera capable of scattering the light to create a halo aura.  Postwork is easier.
bigglobe ( ) posted Thu, 07 February 2013 at 10:20 AM · edited Thu, 07 February 2013 at 10:23 AM
If I use spotlights behind my character, it probably wouldn't look like my character is glowing. I wan't the outline of my character to glow but also the character himself/herself.
This is another example of the type of glow that I would like to apply.
https://96122a9bc9-custmedia.vresp.com/11c7f9ec08/Angel%20with%20glowing%20light%20in%20hand.jpg
Is there a tutorial on how I can do this effectively? You guys have provided good information that will be more useful once I learn more about poser. Right now, I don't know how to take many of these actions in poser. I need more step by step instruction. I will still test out your suggestions to see if I can learn something from them. I suppose I can also find a way to add glow to my character though a photo editing program, but it might require brushwork, which often takes a considerable amount of time.
charlie43 ( ) posted Thu, 07 February 2013 at 10:22 AM
In PS or Gimp, create a new layer ABOVE background layer. Set this layer in blending mode to "overlay."  Use a soft brush that wil match the size of your work, and set hardness to zero. Set the brush to 35-50% opacity. With a little experimentation, you can achieve the effect you desire.
HTH
C~
3doutlaw ( ) posted Thu, 07 February 2013 at 10:45 AM · edited Thu, 07 February 2013 at 10:46 AM
Simple postwork glow.  Takes about 5-10 minutes.  Can be applied to any object, via layers.
(no brushing)
