Mon, Dec 23, 11:46 AM CST
Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2024 Dec 22 11:25 pm)
Check out the
Subject: SILO materials problem
VolcanicMink ( ) posted Fri, 08 February 2013 at 1:07 PM · edited Sun, 28 July 2024 at 2:53 PM
What? No Silo forum??
I tried using the materials editor, and it not only turned everything in the scene to the new material, but designated it as the default. For all the files. Now everything is leather! The problem with that is that it makes it very difficult to see the mesh.
How do I get the normal default back (no texture)?
Thanks!!
fly028 ( ) posted Sat, 09 February 2013 at 1:28 AM · edited Sat, 09 February 2013 at 1:33 AM
Hello,
In your scene, just select your entire model, select the object (the box icon), then, in poly mode, select all the "faces"(polys), then display your material tab, select the "default" material icon and click "apply". All your model should be back with the default material(be sure that there is no image declared in the texture path, if it's the case, erase it).
In the material tab, create a "new" material. You'll see a new name "material1". Replace by "leather" and press enter.
Then, in poly mode, select the face you want to be with your new "leather" material. When it's done, go to the material tab, select leather material and apply.
Now, only your selected faces sould be with the "leather" material.
For the material tab: Maybe in your default setting, there is a material map declared. So, everytime you try to make a new scene, this material appears as a default material.
Just go in your material tab, select default and in "texture", erase the path of your image map. Now, you should be able to see your new mesh again.
hope it helps
VolcanicMink ( ) posted Sun, 10 February 2013 at 2:59 PM
Thank you! I think we're OK now.
Overall, Silo has been the most user-friendly modelling program I've tried (which has included most of the freebies and many of the lower-priced programs). It has lots of great new-user tutorials, as well. Still, I stumble over the simple things... Thanks again!
fly028 ( ) posted Sun, 10 February 2013 at 11:56 PM
You're welcome,
i had also a lot of modeling programs. Modeling was a pain...I learned with Fugazi's tutorials and bought Silo for this purpose. I agree, it is really friendly. Now, with some practice, i really enjoy modeling :-)
VolcanicMink ( ) posted Tue, 12 February 2013 at 10:28 AM
I will need a lot more practice before I will actually enjoy it! At this point it is a personal challenge that I refuse to give up on. Your help has made my challenge much easier.
fly028 ( ) posted Tue, 12 February 2013 at 10:39 AM
You're welcome
