Wed, Jan 8, 2:07 PM CST
Subject: Creating a face morph
Renderholic ( ) posted Fri, 15 February 2013 at 1:42 PM · edited Wed, 08 January 2025 at 1:42 PM
Online Now!
If I load and adjust the various head morphs in V4 to create a custom face, can someone tell me how to save that as a face (.fc) morph file?
markschum ( ) posted Fri, 15 February 2013 at 2:06 PM
If it is just dial settings I think it works like a limited pose file. Clixk on the + sign to add to the library and maybe check the box to save the morph channels.
It should be in the manual (off the help menu)
lesbentley ( ) posted Fri, 15 February 2013 at 9:26 PM · edited Fri, 15 February 2013 at 9:27 PM
To save it as an fc2 file, open the libraries 'Expressions' palette, browse to the part of the library that you want to save it to, click the "+" symbol at the bottom of the palette. This saves the parameter value for the head morphs. In order for the fc2 file to work correctly on a figure, you need to have the same morphs present in the head as when the fc2 file was saved.
As an alternative to the above, you can use SceneFixer to save a delta injection pose. Such a pose will embed the morph deltas in the pose file, and thus it can apply the face morph even when no other morphs have not been injected into the figure.
