Mon, Jan 6, 10:19 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 04 8:20 pm)
Carrara Free Stuff here.
Subject: Meatball Model Plant
willf ( ) posted Mon, 17 September 2001 at 12:23 AM · edited Sun, 05 January 2025 at 4:19 AM
Image says it all.
pc_artist ( ) posted Mon, 17 September 2001 at 3:28 AM
kewl tip.. neat image and model too
" The Only Limit is your imagination "
MarkBremmer ( ) posted Mon, 17 September 2001 at 10:54 AM
Haven't tried that before. Thanks for the tip. Mark
AzChip ( ) posted Fri, 21 September 2001 at 5:31 PM
The spike deformer is a great tool. I've also used the explode deformer to form a "cloud" of leaves -- very effective for distant foliage. I've found that if you deform and object and then jump into the vertex modeler with deformations still applied (or export the file to a different format then re-import it), the plant becomes far less difficult for the program to handle. That is, it's not having to calculate the deformed version of the object every frame. It makes moving these plant objects around much simpler. - Dex
schwa ( ) posted Fri, 21 September 2001 at 8:33 PM
thats pretty frickin kewl, wish i had the time to sit down more often, to many programs, not enough time
litst ( ) posted Fri, 21 September 2001 at 8:59 PM
Just a tip : Chip, you can make a boolean union of an empty vertex object and the atomized vertex object . You end with a vertex object deformed with the atomize deformer . Of course, the file will be bigger, but the program won't have to calculate the all thing every time you move your object . It should work the same with Will's technique . litst
