Blender F.A.Q (Last Updated: 2024 Oct 20 9:34 pm)
The .mtl file does not contain any textures it just contains the texture file path information. In the zip file that you downloaded was there any texture files included?
My Renderosity Store
Virtual Furnishing
My Portfolio
I just realized I have been saying this wrong...When I open the downloaded file in Blender, the textures ARE there..It's when I export them as an .obj file that I lose the texture....Perhaps I didn't check something in exporting?
Thank you all for your help..Nice models made in blender
Hope to get this fixed soon..
The textures have probably been packed into the blend file on saving.
Try this:
Open the file (.blend) you downloaded from Blendswap in Blender.
Go to File>External Data>Unpack into files
Select from the options that come up now - Write Files to Current Directory
If you navigate back to the folder that has the Blendswap .blend there should now be a folder named "textures" which contains the texture files.
Back in Blender export the model to .obj format saving it into the folder with the textures.
Open Bryce and import the model. If you get an error message about not finding textures just continue on, Bryce should then open up a window so you can browse to the textures but if you saved the .obj to the same folder then you should already be there. If you are in the folder with the textures click on open otherwise navigate to where this folder is. Back in Bryce the textures should now have been applied and it should render correctly.
Virtual Furnishing
My Portfolio
I downloaded a nice model from Blender Swap in .obj format. Along with it was the .mtl file. When I import it into Bryce there are no textures. Was I supposed to do something special to ensure that the textures came along...How do I get the textures out of the .mtl
Thank You
