Sat, Feb 8, 4:59 PM CST
Subject: EZSkin 2
Sheedee ( ) posted Thu, 04 April 2013 at 7:07 AM · edited Sat, 08 February 2025 at 4:49 PM
Hello;
It says on the vendor page that what is required for EZSkin 2 to work is
Poser 9 SR2.1+
I have Poser Pro 2012...does this mean that it will not work in Poser Pro 2012?...
http://www.runtimedna.com/EZSkin-2.html
thanks for viewing
ghostman ( ) posted Thu, 04 April 2013 at 7:11 AM
yes it will work for you.
"Dream like you'll live forever. Live like you'll die tomorrow."
Join PoserLounge Chat
hborre ( ) posted Thu, 04 April 2013 at 8:57 AM
Online Now!
But you need the service releases installed, same as P9.
Zanzo ( ) posted Thu, 04 April 2013 at 8:57 AM · edited Thu, 04 April 2013 at 8:58 AM
You need to have the poser application that specifically says: "Poser 9 SR2.1+" exactly as it says.  With the plus at the end and everything.  SR3 will not work, nor will SR1, but SR2 will work perfectly.  Also it has to be a + not a minus.
Poser 9 SR2.2+ would not work because there is a 2 instead of a one.
Posre 9 SF2.2+ would not work either becaase the r & the e have been switched.
It's hard finding a version that works that matches the text exactly. I'm in the same boat. I think i'm just gonna give up and format my hard drive.
..... lawlz kidding btw.. haha. cheers...
OF COURSE IT WILL WORK MAN.
ghostman ( ) posted Thu, 04 April 2013 at 9:06 AM
ANY SR from SR 2.1 and above will work. Hence the + sign. Means that ANY SR above that one works.
questo ( ) posted Mon, 08 April 2013 at 3:51 AM
Just to confirm, I have PP2012 with SP 3 installed and EZSkin 2 and EZSkin 2 works fine, no problems.
hornet3d ( ) posted Mon, 08 April 2013 at 3:58 AM
Quote - Just to confirm, I have PP2012 with SP 3 installed and EZSkin 2 and EZSkin 2 works fine, no problems.
Likewise, I have been using it with Poser 2012 and SP3.  If it does not work in this combination I would suspect there is a particular issue with the system in question or the installation is incorrect.
parkdalegardener ( ) posted Mon, 08 April 2013 at 7:37 AM
Works fine with sr 3.1
