Hillbilly high architecture. Needs hinges on the doors and some kind of bolts to lock them. Wanted the look of something that has been repaired, meaning old, weathered wood, I think that came out fair. I also wanted to be able to have just a dirt floor, so the top of the foundation is the ground level, hide the foundation and the building is on the ground.
Path of least resistance taken. I should have it up sometime today.
Doric.
The "I" in Doric is Silent.
Fine '20s garage.
Dirt floor would be appropriate. I've had several garages like this and they all had dirt floors. Made it harder to grease a balljoint, but also made it very easy to clean the floor.
My python page
My ShareCG freebies
Quote - Fine '20s garage.
Umm, the inspiraton is my own garage, although mine's two car, with no room to walk if two cars are in it. Father in law built it in the late 1930's. '66 Chrysler Newport barely made it in, but then you couldn't open the front door, which at that time swung in. Now, cars are smaller and garages bigger.
Mine is a good example why garage floors should not be poured in one piece. There are some rather odd shaped divisions now. None of which were planned.
Doric.
Simple garage.
SImple studs and bracing, footer and cap
Simple rafters and stretchers
Simple textures, using displacement map.
And still I'm forgetting to put the blasted material zones in before I export from Wings.
Back to drawing board.
Doric.
