Tue, Feb 18, 8:38 AM CST
Subject: Problem in vue with a certain figure imported from poser.
makis12 ( ) posted Sat, 20 April 2013 at 9:45 AM · edited Mon, 17 February 2025 at 11:09 PM
I have created a figure in poser.It s an alien and i have changed his colour from the default green to orange.The thing is that i import this figure to vue and when i render my scene this figure looks something like very dark green.I mean it s not orange ,it looks so dark coloured.Why is this happening.Please help.I want to fix this.It s wasting my time and i can t really work with my project if i don t find the solution to this.
thd777 ( ) posted Sat, 20 April 2013 at 10:43 AM
How did you change the color? If you did it via the material room nodes, are you importing the .pz3 with the "Render Materials with the Poser Shader Tree" option enabled?
TD
makis12 ( ) posted Sat, 20 April 2013 at 10:55 AM
No i didn t do it via material room.I used the colour(c) button from the editing tools.
thd777 ( ) posted Sat, 20 April 2013 at 11:05 AM · edited Sat, 20 April 2013 at 11:06 AM
Quote - No i didn t do it via material room.I used the colour(c) button from the editing tools.
The color tool has no effect on the actual material. It does not transfer to any other program and does not even render in Poser. It is intended for making things easier to find in the display.
You need to either:
-  Apply your changes in the poser material room and then transfer to Vue with Poser shaders enable
  • Modify the textures in an editing program
  • apply the color change in  Vue via texture map modifier node or the color correction/color mixing.
TD
makis12 ( ) posted Sat, 20 April 2013 at 11:15 AM
Ok buddy.Thanks for the replies
ShawnDriscoll ( ) posted Sat, 20 April 2013 at 10:54 PM
Color tool?  I didn't know Poser had such a thing.
