Tue, Jan 21, 8:07 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 4:30 pm)
Subject: load morph target
ghostship2 ( ) posted Thu, 25 April 2013 at 3:34 PM · edited Tue, 21 January 2025 at 10:44 AM
I need to get the V4 transmaped brows to conform to a character morph. Im guessing that I need to "load morph target" from the properties menue on the body part. Not sure what I need to load there...the geometry file from the vendor? What if the morph is from dial twists only? Would the FBM function in Wardrobe Wizard aid in this problem?
luckybears ( ) posted Thu, 25 April 2013 at 4:32 PM
Maybe unticking 'use external morph..." in EDIT preferences might work, sadly, unless you have the actal morphp target you might be in the shit.. This is a chronic prblem in poser that has not been satisfactorily resolved
ghostship2 ( ) posted Thu, 25 April 2013 at 5:03 PM
I had that unticked already but for a different reason. Im bummed. Spent a bunch of time making a custom texture that was bump mapped properly with the brows on a different map from the skin for close ups. I guess I can use it on the unmorphed figure but still bummed all the same.
jestmart ( ) posted Thu, 25 April 2013 at 7:36 PM
This isn't Poser's problem,  DAZ never put all the face morphs into the eyebrow.  Because the eyebrow is part of V4 I don't think the usual way to transfer figure morphs to conformers will be able to help.  The only way I see is to a modeling program the can skrink or snap the eyebrow to the face.  Of course not only will you need to do this for the custom head morph but also for every expression morph.
primorge ( ) posted Thu, 25 April 2013 at 8:09 PM
If I'm understanding your question correctly...
Unless the vendor morphed both the eyebrow body part and the head there won't be a match, you can check by toggling visibility on the eyebrow body part. I'm going to assume that you've already discovered that the visible brow body part in fact doesn't match. From my experience with using commercial character morphs the brow body part isn't exported for the custom morph process and consequently doesn't match, there's really no way to remedy this. There are exceptions though, I think that Fabiana often creates her morphs to include the brows for instance.
If the head morph is derived solely from dial spinning the Daz morphs there should be a match so you wouldn't be experiencing this issue.
BTW use external binary morphs has zero to do with this issue and has nothing to do with "a chronic problem in Poser"... Most vendors simply don't create their custom morphs to include the eyebrow and don't bother with morphing said body part along with the head body part.
You could however create your own morph from dial spinning or in an external modeler (including the brow body part) and your custom texture will blend fine with the morph... Warning though, morphing the brow to match the head is a royal PITA and you'll be battling some kind of offset distortions more than likely. Probably why most don't bother, and the fact that few use the brow body part.
Being that you are using the brow area as transmapped you could try just pushing and manipulating the brow body part to some kind of semblance of a match with the putty tool (or even an external modeler, export the head morph as guide)... there's less geometry that needs to match and the brows would probably look ok with a bit of offset, just an idea.
primorge ( ) posted Thu, 25 April 2013 at 8:24 PM
Edit_ I just tested the Daz Morphs++ and A4 morphs on V4 and they seem to work and conform perfectly with the eyebrow body part visible. In some instances and at higher values very, very minor offset of the eyebrow body part is occuring or it might be my imagination... all in all, with transmapped brows I would expect the Daz Morphs to work perfectly.
Check for yourself.
ghostship2 ( ) posted Fri, 26 April 2013 at 5:46 PM
thanks for the info. I looked into a few of the characters I have for V4 and spotted the ones with eyebrow poses.
