Sun, Feb 2, 9:04 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Shader program from Run Time dna
westcat ( ) posted Wed, 08 May 2013 at 7:34 AM · edited Thu, 30 January 2025 at 1:33 PM
Hi
Python script is required to use LuLu new Body Gloves.  They look super hot, but I have Poser 7 on an XP PC and cannot get the plugin here http://www.runtimedna.com/Advanced-Shaders.html  to work, anybody else have problems with this plug in ?    It is supposed to work automatically when you just click on the respective pose file for the sheer and HOT body glove. http://www.renderosity.com/mod/bcs/b-1-1-click-latex-super-skinz-bodygloves/98604
Nothing happens though   The plugin is aparently very fussy about where it is installed
Runtime Error: Bad magic numbers in .pyc file
traceback (most recent call list):
File "C:Program FilesSmith MicroPoser Pro
2012RuntimelibrariesPose00_DAZ's Victoria4!!!V4_ClothesLuLuLatexTattoosCorset-Design-Black.py, line 4, in
result=
ASM_Load_Shader(r":Runtime:Shaders:lululee:Benevolence:Latex-Designs:8Corset-Design-Black.sh8")
NameError: name'ASM_Load_Shader' is not defined
In Poser Pro I get
NULL (or empty) script name passed to PEPythonEngine:DoScript()
and in Poser 7 I still get nothing.  What am I doing wrong HELP
Snarlygribbly ( ) posted Wed, 08 May 2013 at 7:44 AM
A bad magic number means that the script is incompatible with the version of Poser Python installed. As the version of Poser Python is tied to the version of the Poser application, this means that the script is not designed to work with your version of Poser.
Free stuff @ https://poser.cobrablade.net/
westcat ( ) posted Wed, 08 May 2013 at 7:51 AM
Well it does not work in Poser 9 either.  I  am going to try Poser 8 this weekend  thanks
semidieu ( ) posted Mon, 13 May 2013 at 7:23 AM
In your account, you should have two zip files:
one is for Poser 8
one is for Poser 9 (should ends with P9)
You will have to install only the one designed for your Poser's version!
Let me know!
Basil
PS. I did create it :)
westcat ( ) posted Wed, 15 May 2013 at 7:30 AM
Got it to work in Poser 8 no sweat, here is the resulting render http://www.renderosity.com/mod/gallery/index.php?image_id=2439482 nudity
