Go for it. Not all of us can afford the fitting room. And those who can will most likely want new stuff too. After all how many times can you use dressX before getting bored with it. And the fitting room goes both ways. People who use V4 exclusively will be able totake advantage of stuff made for Anastatia too.
Quote - Just a hint. Be sure it is all welded.
PP2014 fitting room likes welded clothing.
Looking good, nice job.
All the fussion app's likes the mesh welded too.
The
Artist that will fight for decades to conquer their media.
Well, I don't know what command term Blender uses, but for use in Poser's new fitting room, what is important is that each garment is a single connected mesh (or group things like belts as constrained, and buttons as rigid decorations). Many conforming clothing items have collars, cuffs, pockets, and hemlines which are not actually connected to the body of the shirt, for example. If you try to use it as dynamic cloth, it falls apart. Similarly, in the fitting room, the pieces pull apart here and there.
OSes: Win7Prox64, Win7Ultx64
Alt M : Merge.
some ways to maybe check
if you grab a line and it rips 2 points at same place apart then its not merged.
if you subdivide and it don't round then it's not merged.
shrink wrap also.
if blender has select connected
The
Quote - I'd like this for Anastasia.
I'd like it for Miki also.......
ssgbryan : You have Poser Pro 14 .it will work for any and all meshes for you.
The
