Mon, Jan 6, 7:33 PM CST
Subject: Who ya gonna call?
seachnasaigh ( ) posted Wed, 26 June 2013 at 1:25 AM · edited Sat, 04 January 2025 at 10:48 PM
     Uploaded and awaiting approval for the freestuff area:  Ghostbusters for Rex and Roxie.
gb.     trap.     pack.     jumper.
     The jumpsuits are dynamic.  Oh, don't be skeered!  I already have the dynamics  set up for you.
     The packs could be used with other dolls in P5 and up, but to get the cool light-casting effect requires P9 or later.
     I included an EZ-posed anti-proton capture beam figure, but only use it if you need to make a custom beam shape, because it slows Poser down to a crawl.  In fact, if you do use it, I'd get the beam posed, then export the beam as an OBJ, and export the beam emitter as an OBJ, then re-import those two OBJs to use as props.
     The architectural bits can be moved a bit -or hidden- for camera access.
     The leaves of the chairs use SSS.  Just about everything requires displacement (min displacement bounds=1) and IDL.
     The zip is 33.2MB and includes jumpsuits, proton packs, capture beams, ecto-trap (with special effects), PKE meter, ghost, underground chamber, and some starter poses.  Gun cable, ecto-trap cable, and the universal capture beam figure are EZ-posed.
     Zip is in standard runtime format.  To use, look in runtimelibrariescharacterGhostbusters for preloaded Rex and Roxie figures.  Obviously, you must already have Rex and Roxie, since my cr2s merely call the SM files (they aren't in my pack).  The ecto-trap and the "shape-your-own" capture beam (8x128) are also in this folder.
     Helpful starter poses are in runtimelibrariesposeGhostbusters.
     In runtimelibrariespropsGhostbusters you'll find the inner sanctum room (it's from my Galadriel's Mirror playset enviro), the PKE meter, and lots of loose parts.
     All of the geometries are remotely referenced, in case someone wants to make/distribute an alternative texture set.
     This set is free for both personal and commercial rendering. Do not redistribute, with the exception of using a 3D printing service.
     Copyright 2009 and 2013 by seachnasaigh.
TrekkieGrrrl ( ) posted Wed, 26 June 2013 at 6:06 AM
Oooh looks nice! Thanks!
monkeycloud ( ) posted Wed, 26 June 2013 at 12:28 PM
This looks phantastic seachnasaigh! :-)
