You get media players that add frames in. Look at Splash Player. You can watch a 24fps movie at over 60 fps by dialling up the motion2 slider in the player. It uses your GPU card to draw in the frames. Thats just an alternative solution, but might save you time on skipping out the conversion process. They have a version you can download and test. http://mirillis.com/en/products/splash.html There is a watch motion2 demo clip on the right of the site so you can see it in action.
Quote - For true 60 frames per second you actually need 60 different images per second.
How you can do that in Poser I don't know when you only got a 30 frame timeline. Can it be streched to 60 ?
If you type a new number where the 30 is, you will change the frame count to whatever you just typed in.
Attached Link: http://slowmovideo.granjow.net/index.html
slomoVideo is an open source program that slows video down, I don't know if it is what you may be after, but it maybe an option. It's Windows and Linux, but can run on Mac osX via WINE.The demo videos showing the slow-mo effect in use are pretty cool.
Okay first you'll need 60 frames or more of animation. Then you'll need to go to the Make Movie menu option. A dialog will appear. Set the FRAME RATE to 60. There you go. Now your animation should play back at that speed.
Note that you can use fewer than 60 frames with this option but it will be less than a second long of animation.
I have a client. He has an adult video that also uses a toy plugin to computer. he wants 60fps so if the user slows his movements, the animation slows also without becoming chopy. How do I get a true 60fps? Does straight to QT or using image sequence make a difference? I use Adobe AE to assemble the image squence. Do I leave it at the frame rate, or manually change it to 60fps, or just go straight to QT file from Poser? Thanks.
