Fri, Nov 22, 8:44 AM CST
Subject: Updating old python scripts for PP2014?
AnAardvark ( ) posted Fri, 28 June 2013 at 9:54 AM · edited Sun, 17 November 2024 at 11:51 PM
Is there any simple way to update old python scripts? I know that there may still be some incompatable aspects regarding the material room etc., but I was wondering if there was a way to at least fix the basics that prevent old scripts from running.
hornet3d ( ) posted Fri, 28 June 2013 at 10:39 AM · edited Fri, 28 June 2013 at 10:40 AM
Quote - Is there any simple way to update old python scripts? I know that there may still be some incompatable aspects regarding the material room etc., but I was wondering if there was a way to at least fix the basics that prevent old scripts from running.
It depends on how old the scripts are.  A lot of the scripts needed to be modified to run in Poser 9/2012 if they were from earlier releases.  If they ran in Poser 9 but not 2014 then the only ones I believe had a problem if they made specific reference to Poser 9.
In any case most of the scripts now work in Poser 10/2014 so it might be an idea to specify the scripts you are having problems with.
hborre ( ) posted Fri, 28 June 2013 at 1:37 PM
Online Now!
IIRC, script changes began in P8/PP2010 and, then again, in P9/PP2012 where they remained the same in P10/PP2014.  For the most part, compiled scripts (.pyc) are the files that need to be recompiled by the vendors.  The .py format appears to work in most versions without re-editing.
icprncss2 ( ) posted Fri, 28 June 2013 at 2:36 PM
Does the script make use of Tkinter?
AnAardvark ( ) posted Mon, 01 July 2013 at 12:11 PM
They do make use of Tkinter. Most of them are not compiled, but are from vendors which have disapeared, or are old freebies.
perpetuavelouria ( ) posted Wed, 10 July 2013 at 4:18 AM
Hi - sorry to semi-hijack - Where do I put scripts in order for them to appear in PP 2014?
WandW ( ) posted Wed, 10 July 2013 at 10:16 AM
Copy them to the Poser Program runtime, in the Python/Poserscripts/ScriptsMenu Folder...
TrekkieGrrrl ( ) posted Wed, 10 July 2013 at 10:37 AM
I just run the ordinary .py scripts from my old runtimes. Be it the Poser 4 original runtime or one of the newer. No problems with those.
perpetuavelouria ( ) posted Thu, 11 July 2013 at 5:11 AM
Quote - Copy them to the Poser Program runtime, in the Python/Poserscripts/ScriptsMenu Folder...
Thanks so much :)
