Fri, Nov 22, 2:00 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: wxPython remember dock location
3doutlaw ( ) posted Wed, 26 June 2013 at 10:20 PM · edited Fri, 22 November 2024 at 12:32 AM
For wxPython windows, how do you set it to remember the location of the docked window on the next launch of Poser?  I can get it docking, and I found and understand how to make it non-docking....
What I don't understand is how to get it to remember the dock settings?  When I restart, my script always starts undocked again?
Thanks!
PhilC ( ) posted Thu, 27 June 2013 at 1:58 AM
userDir = os.path.join(poser.PrefsLocation(),"My Script") iniFile = os.path.join(userDir,"MyScript.ini") scene = poser.Scene() man = poser.WxAuiManager() root = man.GetManagedWindow()
class MyClass(wx.ScrolledWindow):
    def __init__(self, parent):
        etc
    def MyFunction(self):
        etc
win = MyClass(root)
def readINIFile(filepath):
    # dock value of one or zero read from ini file
def main():
    readINIFile(iniFile)
    win.MyFunction()
    man.AddPane(win, wx.aui.AuiPaneInfo().
                    Caption("Create Prop").CaptionVisible(True).GripperTop(True).
                    Floatable(True).Resizable(True).DestroyOnClose(True).Dockable(dock).
                    FloatingSize(wx.Size(330, 895)).CloseButton(True).MaxSize(wx.Size(330, 895)).
                    MinSize(wx.Size(330, 250)))
    info = man.GetPane(win)
    info.Show()
    man.Update()
main()
I've used the format above to create a dockable window. The option to dock or not is set by the value read from the ini file on start up. Trouble is that once I docked it, it would always start up docked. I could never again get it to start up un-docked. I've looked for a possible setting in the Poser.ini file but not found one. Not exactly an answer to your problem but may shed some light on it. How are you creating the dockable window for your script?
Fenier ( ) posted Thu, 27 June 2013 at 6:23 AM
You would, on dock, have to set state in a file somewhere.
On script load, you would have to read that file.
When you un-dock it, you must update that file to reflect current state.
So three parts:
On Dock - Write to File
On UnDock - Write to File
On Load - Read file
3doutlaw ( ) posted Thu, 27 June 2013 at 12:18 PM
Thanks for the replies, guys!
I got it docking on startup, but now I realize that I probably have to also read/save the position of the docked pane as well as "if" it is docked or not, so that I can redock it at the same position it was at.
Fenier ( ) posted Thu, 27 June 2013 at 3:42 PM
Correct.
You'd save the exact state to the file, and read that file on startup.
You should have a if clause in there, to if there is no stored position  / state then THIS (whatever this is) should be used.
3doutlaw ( ) posted Thu, 27 June 2013 at 4:31 PM
You don't by any chance have an example do you?  (...not the write/read from file, I get that...its the Read Position and Write Position of the pane) I've been toying with it all day, and using this, but all I've managed to do is mess it up.
In exasperation, I've all but decided to just force it to float, which is not ideal.
Dizzi ( ) posted Fri, 28 June 2013 at 6:08 AM
Have a look at my "MorphScale" script in freestuff. It does load and save its position.
But you cannot force a docked position, easily (and I don't to that). The only way to do that easily is to use the UI dots. They store and restore the whole UI for each room including the wxPython windows.
semidieu ( ) posted Sun, 30 June 2013 at 2:12 PM · edited Sun, 30 June 2013 at 2:15 PM
With Poser 9+, this is working if you use the new 'addons' system.
If you don't use the addons system, I was able to make it work to something similar to what PhilC did.
Saving dock info:
  1. Read the pane settings.
  2. Save it in a .ini file.
Restoring dock info:
  1. Read the .ini file.
  2. Create the pane with the settings from the .ini file.
There are some strange things happening... And the position must be adjusted...
When I load a new pange, I'm using a function that read the ini file, the the position (xp, yp), the size (xs, ys), the dock/float status (DOCK), the various docking information (D - Direction, L - layer, P - position and R - row) and the dockable/floatable status.
Getting the docking information:
pane.dock_direction,pane.dock_layer,pane.dock_pos,pane.dock_rowThen to restore the settings, I read the ini file and get the informations:
(xp,yp,xs,ys,DOCK, D, L, P, R, DOCKABLE) =
SWPC_SizeAndPosInstances()
Finally, I'm loading all using this:
if DOCK:<br></br>
  pane.Dock()<br></br>
else:<br></br>
  pane.Float()<br></br>
pane.Dockable(DOCKABLE)<br></br>
pane.Floatable(DOCKABLE)<br></br>
pane.Caption(name).CaptionVisible()<br></br>
pane.Resizable()<br></br>
pane.Direction(D).Layer(L).Position(P-1).Row(R)<br></br>
pane.FloatingSize(wx.Size(xs-16, ys-34))<br></br>
pane.FloatingPosition(wx.Point(xp+8, yp+26))<br></br>
pane.BestSize(wx.Size(100,100))<br></br>
pane.MinSize(wx.Size(100,100))<br></br>
pane.CloseButton(True)<br></br>
pane.MinimizeButton(True)<br></br>
pane.DestroyOnClose(True)
Notice the Position(P-1) which adjust the docking position - don't know why it's necessary but this was working for me.
Now... this is an old code and certainly might be better :) Last thing, don't forget the addons if you're developing for the latest version of Poser. It's much better and offers other nice uses :)
3doutlaw ( ) posted Sun, 30 June 2013 at 6:47 PM
Dizzi and Basil, I'll give those a look, and a try thanks!
I looked originally for doco on the addons stuff, but I could not find it?  Is it a seperate PDF I may be missing?
3doutlaw ( ) posted Sun, 30 June 2013 at 10:12 PM
file_495732.txt
Ugh...I worked for a while today with SavePaneInfo and LoadPaneInfo, with awful results.  It would dock only in a single position, and was like in 2 pieces.  A docked piece, and a floating above it piece, that was unselectable.  When I undocked it, it came back together.  It appears to have all of the attributes needed (like Basils listed ones), but I could not get it to work (using Dizzi's example, and a lot of online doco and googling).  Obviously my problem.
I attached it in case anyone has time to take a look.  I stripped it down to the bare docking and setup stuff, so it is pretty small.  It just loads and has a single file->save command, which create an INI file in c:temp.
You'll have to change it to a .py of course...
(feel free to critique...I am trying to improve)
semidieu ( ) posted Mon, 01 July 2013 at 2:37 PM
I think the biggest problem here is the use of the wxFrame. You should use wxPanel instead.
