Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 09 11:05 am)
Ok, the Main Problem :)
I don't know, i find the Dynamic Cloth a little to high at the Back Polstery.
Here a fast Render without the Veins and a few Details missing.
@Holler Thx for the Tip. I will look into it.
(Sorry for my bad Englisch ;)
What is pushing the blanket up, there at the back? It should fall down and it looks odd :)
And I suppose that is part of what you're asking?
Did you use any constrained groups on the blanket? Or did you just start it from somewhere over the couch? it really puzzles me why it drapes like it does.
You could try changing some of the cloth parameters, the fold resistance and the cloth density. That way I think you will get a nicer, more real drape. I can never remember myself if those numbers should be higher or lower to make "softer" cloth so I always end up trying first a very low setting, then a very high and see which does what. Some day I'm sure it will stick to my mind ;)
If all else fails, the Morphing Brush is great to fix dynamic clothes that didn't QUITE do as it should. In this case Id use the shrink to.. and use your figure as the target and "paint" with fairly broad strokes.
One last question: What did you use for the blanket? You should use the High Rez Square for dynamic cloth. (or something modeled to be dynamic, this is really a case where polygons matter :))
![file_495999.jpg](https://live.cdn.renderosity.com/forum/threads/2869747/file_495999.jpg)
Can anyone tell me how i could resolve the following Problems ?Glowing in the Mouth (my first poser Try with a open Mouth)
I don't know how but my Dynamic Cloth is Glowing on the Underside.
Sorry for the Questions but my main Program so far was DAZ Studio with 1-2 Exceptions.
But now with Poser Pro 2014 came the Questions ;)
