Sun, Feb 2, 2:05 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
Subject: please locate box in poser...please help.
LarryWheeler ( ) posted Sun, 30 June 2013 at 6:48 PM · edited Sun, 02 February 2025 at 10:44 AM
when I try to load figures that I have downloaded it comes up with a box that won't go away until I close the poser 9 program. It says "please locate "injdeltas.fbm" what do I have to do to get these figures to load. i have several figures that won't load because of this message. please help
seachnasaigh ( ) posted Sun, 30 June 2013 at 7:47 PM
     Make note of where you installed that downloaded content.  Is that runtime showing in your library?  If not, use the + button and browse to add that runtime.
    You might also look in edit:general preferences:library and set the search to shallow or deep.
hborre ( ) posted Sun, 30 June 2013 at 9:57 PM
It sounds to me that you do not have the Morph++ package installed or it is not located where it is suppose to be originally.  Since you did mention that the characters you possess are downloads, I ask this:
Do the characters require a morph package, and do you have this morph package installed?
flibbits ( ) posted Mon, 08 July 2013 at 12:33 AM
Usually you can cancel searching for missing files.  BUt if you do, something isn't loading into the scene.
Do you have all the runtimes, where the content is loaded, added to the libraries in Poser?
ghostship2 ( ) posted Mon, 08 July 2013 at 10:15 AM
actualy the window does go away...it just loads a new window asking for a different injct delta thingy and will do this till it runs out of alerts to put up on the screen. but yeah, you have to close the program unless you want to close 100+ alert boxes.
