Thu, Nov 14, 9:31 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
Subject: Troubleshooting - Libraries window in Poser Pro 2012
FrozenStar ( ) posted Thu, 18 July 2013 at 11:15 AM · edited Thu, 14 November 2024 at 7:13 PM
Hi. My Poser has started acting up today and I'm not sure what the problem is. I was rendering promos earlier this morning and it worked fine. Closed for 2h, took to Photoshop to work on a new project then restarted Poser but my Libraries window was nowhere to be found. I checked under Window and Libraries was checked. I tried the shortcut Ctrl+Shift+B but it's not bringing it up. I will see it load up and quickly vanish upon computer & Poser restart. The only workaround I have found currently is to have my Library preferences set to Embedded, but even so I can only see it, but not browse through any of it or scroll down.
Does anyone know what the problem could be? I know a reinstall may help solve my problem, but I'd only use it as a last resort, since I have a really big library of installed filled I really don't want to lose.
willyb53 ( ) posted Thu, 18 July 2013 at 11:20 AM
Before you reinstall, try changing your preferences to factory and see if it there.  You may have to build your UI again, but you would have to do that if you reloaded.  After you get it the way you want, set a UI dot so you can go back if you move something off the screen.
Bill
saibabameuk ( ) posted Thu, 18 July 2013 at 11:35 AM
OK guys I now have the butterflies! if I copy all of my poser applications over to a backup drive will that now give a complete Poser Back up!
TrekkieGrrrl ( ) posted Thu, 18 July 2013 at 1:54 PM · edited Thu, 18 July 2013 at 1:54 PM
Saibababa.. with "all my Poser applications" do you then mean your runtimes? Because, yes, you can move those around as you please. And just point Poser to their new location. If you mean the program itself.. not likely. ealier versions didn't require installation per se (I've run Poser 4 off an USB stick just for the fun of it) but later versions need entries in the reg. database.
saibabameuk ( ) posted Thu, 18 July 2013 at 1:58 PM
Great thank you it is my runtimes I am concerned about.
thanks again.
