Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 14 7:46 am)
Well if she is not sticking through, then it could be reversed normals. You could try fliping them back with the grouping tool.You could run the whole thing through the 2face converter program.
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
Attached Link: MDuncan@clintonville.k12.wi.us
Cybermonk... It must be a sizing problem, because I tried the 2Face convertor with no real luck... it was still there. Grey Cat: I checked the CR2 file and both of the stated lines above appeared there... Looks like I will have to take Jim advice and try to figure out how to use magnet or something to correct it... Any ideas on how to go about that? Thanks! MattSelect the dress figures chest, apply the magnet, then select the magnet, go to it's properties, and then click the thing that says "Add Object to deform" or something like that... add the figure's abdomen, and probably the right collar... then adjust the magnet's zone so that it's centered over the middle part of the dress that's cutting into her body... then pull the magnet out, probably a little on the x and a little on the z I doubt that you'll have to move it too far, then make sure you select each body part of the dress that is effected (or is it affected... I STILL never know) by the magnet, and spawn the morph from the magnet... I like to reapply the morph to each part, and then create a full body morph, it saves time, so you only have to adjust one dial, rather than 3 or 4... that probably wasn't helpful...
Gee Whiz, I see what you mean! Darned if I know why the dress did that, it hasn't had that problem before. this is a new one on me! I love your beautiful Texture, great job there! The hole seems to be in the area of the chest beneath the arm. I am so sorry you are having this problem. When I created the dress in Poser Pro it conformed to the P4woman beautifully. If the female you are useinng has any breast morphs or chest morphs this is probably the problem, I do not know why but when I have tried to apply some of my clothes to a morphed figure, I get this exact same prob? Its a mystery to me. Sorry I can't help. Lady Luna/ Gloria Gast :-(
