Fri, Jan 10, 11:00 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
Subject: Random Blue Artifacts in PP14
Iuvenis_Scriptor ( ) posted Mon, 05 August 2013 at 1:35 PM · edited Fri, 10 January 2025 at 10:47 PM
I've recently upgraded to PP2014, and I think it's since then that I've occasionally been getting these bizarre sky-blue artifacts in renders.  They pop up rather randomly, but there does seem to be some correlation with the amount of reflection in the scene.  Strangely, just re-building the exact same scene and re-rendering either redistributes them or removes them entirely.  Any ideas would be greatly appreciated!
vilters ( ) posted Mon, 05 August 2013 at 3:01 PM
While the result normally is different, it can be that you are rendering with all material groups in the same SSS groups.
Try setting the skin, eyebals, cornea in different SSS groups.
All surrounding materials should be in different SSS groups.
It is the lower case in the SSS node.
Also check the material setup in the eye area.
hborre ( ) posted Mon, 05 August 2013 at 4:23 PM
Also check the inner mouth and teeth material zones.  If the mouth isn't open, you can remove all SSS related nodes.
vilters ( ) posted Mon, 05 August 2013 at 6:14 PM
I think he is talking about the light blue spots next to the cornea's.
hborre ( ) posted Mon, 05 August 2013 at 7:52 PM
Look closely.  The entire lower face has a bluish tinge to it.  But on closer examination, I see what you are referring.  Silly me, forgot to click on the image to enlarge it.  DUH!
