Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
If your asking how the plugin is coming, I have been using it and it is good! Here is an animated gif.
I did find that Carrara using this, if you leave a texture as the color, use sampling and not Fast Mip Map, as the latter will cause a crash due to a momory leak or something.
This is using the new release C85
BTW, 96 frames rendered in 5 min
As you can see, with the plane, there is a shadow being thrown on the skirt and boots, but this does not make sense, as the light is coming from the same direction as the camera? I was thinking maybe its a reflection, but when I turn off Cast/Receive shadows for the plane, this goes away.
Any thoughts appreciated. (for now I am unchecking cast shadows)
...and since I am asking questions, one for zgock: Using the formula for the eye shader (I guess) how do I reduce the size of the white circular reflections?
Attached Link: YAToon 2.0 wiki
Hi.I released re-written Toon plugin "YAToon 2.0" with open source.
sources and binaries are linked URL.
release status is alpha3. need more testers.
also need check English in Users Guide and Tutorial.
(Cos It is just google transrated from Japanese manuals)
thanks.
