Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
you need to get the material
get the shader tree
get the PoserSurface node
change the diffuse color
refresh the shader tree
redraw the scene
import poser
scn = poser.Scene()
fig = scn.CurrentFigure()
mats = fig.Materials()
for mat in mats:
tree = mat.shadertree()
bnode = tree.Node(0)
dc = bnode.InputbyInternalName("diffuse-color")
dc.SetColor(255,255,255) # color code in r,g,b
tree.refresh()
scn.DrawAll()
you need to check the commands because I did this from memory.
This method tints an image map with the given color. You can get better results with other methods.
Quote - Pootling around, and wondered about whether there was a simple way to 'drow-ify' some of my favourite V4 characters.
What I'm looking for is a simple way to load up a favourite texture, and then run a script to change the ambient (or other node) colours all at once, rather than click and change each individually in the materials room.
Is it possible? Is it do-able via a script to change them all to the same colour at once rather slog through material after material?
Any advice...?
As Hborre said, EZSkin can do this but makes other changes too (applying SSS) which you might not want.
Markschum's approach is also good, but only works if the shader tree is plugged into the Diffuse_Color node. It will have no effect (or need to be modified) if the shader tree is plugged into another node, such as Alternate Diffuse.
My MatHelper script allows you to copy shaders from one mat zone to several others simultaneously, but retaining the texture maps of the other zones. It might be close to what you want.
Free stuff @ https://poser.cobrablade.net/
Any advice...?
