Thu, Nov 28, 3:58 PM CST
Subject: Long Curls
Kagato98 ( ) posted Mon, 22 November 1999 at 4:49 PM ยท edited Mon, 04 November 2024 at 5:24 PM
I downloaded that new hair in the download section (the blond hair that everyone has been talking about) and I decoded it, and then why I tried it, it told me that it caught a C exception or something like that.....whats the problem?
shredboy ( ) posted Mon, 22 November 1999 at 7:12 PM
it proabably means you don't have enough ram to use it... I have that happen all the time with large texture files(I have 64 megs)Try shrinking the tex and trans maps in half... They might work but won't look as good.:(
TyggerBob ( ) posted Mon, 22 November 1999 at 11:06 PM
If it makes you feel any better, I have 160MB and still get it sometimes :) TB
Nance ( ) posted Mon, 22 November 1999 at 11:16 PM
It opens OK for me on a 10Mb .CR2 with only 32 Mb ram. But Shredboy is right in that usually C-Exception errors occur for me when memory is thin. Try opening it without any maps, on a cr2 with no morph targets, like one of the default child figures, to see if memory is the problem. Sounds like you got everything in the right folders (or you would get an "OBJ not found" type of error), but after repeated attempts, delete the .RSR for the object file (in the Geometries folder) and let Poser rebuild it. It may have become corrupted on the first attempt and even if you re-install the object file, Poser will ignore the .OBJ file and still load from any existing .RSR first.
