Mon, Feb 17, 11:24 PM CST
Forum Moderators: RedPhantom
Subject: Loading Morph Targets
chud ( ) posted Sat, 24 August 2013 at 9:51 PM · edited Wed, 22 January 2025 at 5:26 PM
Is there a way to load more than one morph target at a time for a figure's head ?
markschum ( ) posted Sat, 24 August 2013 at 9:59 PM
If you load a morph target (obj file) you get a prompt to name the morph. Load each in turn and give each a unique name. Then sert the new dials as needed. You need to save the figure to the figure library to keep the morphs.
so one at a time but as many as you need. There are scripts to load morphs to a figure as a batch process.
chud ( ) posted Sat, 24 August 2013 at 10:18 PM
Thank you for the info. Where can I find said scripts?
willyb53 ( ) posted Sun, 25 August 2013 at 7:49 AM
here is one:
http://www.runtimedna.com/Morph-IMP.html
Bill
markschum ( ) posted Sun, 25 August 2013 at 8:51 AM
I have one I wrote for a specific product. I got tired of manually adding 50 or so morphs to a conforming figure every time I had to fix something. I will dig it out for you.
It uses a folder structure of Product/body part name/morph name for the files.
It reads the product folderr and for each body part folder loads all the morph obj files.
It may take a few hours for me to find it in my backups. I am away from home until late this afternoon.
markschum ( ) posted Sun, 25 August 2013 at 10:31 AM · edited Sun, 25 August 2013 at 10:34 AM
file_497579.txt
Heres the script.
you need to change the line that sets the folder to start in. c;tempmy... will point to your work folder.
The script does some error checking and prints an error if the load of a morph fails.
Work on a copy of the figure or at least have a good backup.
remember to save the figure after loading and testing the morphs.
chud ( ) posted Mon, 26 August 2013 at 11:13 AM
Thanks everyone. They did the trick!
