Thu, Nov 7, 7:13 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 07 7:06 am)
Subject: Loading V6 into Poser 2014
jifl ( ) posted Tue, 27 August 2013 at 8:24 AM · edited Thu, 07 November 2024 at 6:44 AM
I am trying to load V6 into Poser Pro 2014 using the DSON. I thought that I had installed all the core files but aparently not When I try to load it I receive an error message that
"rybelle_lashesdis.jpg" cannot be found:) Which core file have I not installed?
Thx in adevance,
jifl
Medzinatar ( ) posted Tue, 27 August 2013 at 8:53 AM
There are only two files for V6,
IM00016281-01_Victoria6.zip contains all the textures and geometry.
IM00016281-02_Victoria6PoserCF.zip contains only PCF files (no textures).
You should use search function to find if file is on system.  Also make sure Poser search depth is on.
jifl ( ) posted Tue, 27 August 2013 at 9:17 AM
Quote - There are only two files for V6,
Thank you. I assumed that that I only needed IM00016281-02_Victoria6PoserCF.zip  for Poser and when I loaded the other file then I did find the textures. I am still not able to load V6 but I will carry on trying and I am sure that I will suceed. Thnx again.
jifl
Medzinatar ( ) posted Tue, 27 August 2013 at 9:25 AM
Before you can use V6 (or any other G2F character), you must install
IM00016280-01_Genesis2FemaleStarterEssentials.zip
IM00016280-02_Genesis2FemaleStarterEssentialsPoserCF.zip
jifl ( ) posted Tue, 27 August 2013 at 10:14 AM
Quote - Before you can use V6 (or any other G2F character), you must install
Thnx again. I had only loaded IM00016280-02_Genesis2FemaleStarterEssentialsPoserCF.zip. I loaded the other one and problem is solved. I am now rendering V6 with Reality.
jifl
