Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
Or you could use a proxy. Something like the Poser ball, flattened and parented (and invisible in render) to them both at the appropriate place
Thank you both.
The IK and then parenting worked to a point. I'm making an animation and using the pose dots for the sequence. The problem is when I go back through the sequence the hands turn outward away from the body part they are parented to.
I tried locking the hand part to no avail.
Is there something I'm missing?
Quote - The problem is when I go back through the sequence the hands turn outward away from the body part they are parented to.
Sounds like you have spline interpolation turned on. What you describe sounds like spline interpolation to me. That's exactly what spline interpolation does. Spline interpolation is Posers default mode, so if you don't want it, you have to remember to turn it off.
Hello,
I was wondering if there is a way to parent say, M4 hand to V4's hip and have it remain in place? Is that kind of thing even possible or is there another trick?
Thanks in Advance,
Taioseach
