Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
The Saveall puts all info from all figures into a temp file, then the Restoreall reads the temp file and applies hte info to the figures. So you should be able to close Poser between uses, as long as you don't find "temp.temp" and delete it!
Saveall.py is attached to this message in the usual way, with TXT added to the filename.
My python page
My ShareCG freebies
My python page
My ShareCG freebies
Pose dots are stored as pz2 files (or perhaps pzz, depending on your setup), with the names 'poseDot_#.pz2'. Where '#' stands for a number from 1 to 9.
You could make make backups of the pose dots, then restore tham at some later time, being careful to backup the current set before restoring.
To find where the the pose dots are stored on your PC, use the Windows Search function to find the string 'poseDot_*'. You can cut down the search time by starting the search in your 'Documents and Settings' folder.
Create new folders to store the different sets of pose dots, eg 'Dots_1', 'Dots_2', etc. If you understand how to make batch files, you could speed up the process of copying and restoring sets by creating batch files to automate the tasks.
Hi
I'm working on a project right now that I have to match up the figure from clip to clip.
There's lip sync involved so the first and last frame tend to change a little and I create a pose file from the figure to make them match when I put them together.
The Pose dots would do it easier but they reset when I open a new clip so I can use the ones from the previous one.
Is there a way to move them from file to file?
Mike
If you shoot a mime, do you need a silencer?
