Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
Is it searching for content because you prompted it to do so, or is it searching for files which some prop/figure needs upon loading that prop/figure?
Instead of saying that you have all the updates, tell me the build number. You can see it on the splash screen when you start Poser, or you can use the help/about Poser menu option from the title bar.
What OS are you on? (e.g., Win7 64bit, Vista 32bit, Mac Snow Leopard)
Note to mods: The build and serial numbers have been redacted and replaced with random characters.
<Image deleted to protect poster because it contained the seriel number, which could be used in pirating.>
OSes: Win7Prox64, Win7Ultx64
its when i ask it to search for an item or bunch of items if i dont know exact name eg search all catergories for say shirt sometimes it will just search for ever even with me typing exact name of the item .if i try to cancell the search it will sometimes just stick on cancelling but never finish even if left for hours , this dosnt happen every time though , maybe about 30% of the time.
build number is 10.02.25578
windows 7 home premium 64 bit
In poser 2012 i can never remember having this problem
One other thing; are you using the embedded library or the floating external library?
Check at edit:general preferences:library
The embedded library uses Flash; the separate process (you'll see a separate library icon in the task bar, beside the Poser icon) floating library uses Air. It occurred to me to wonder if it happens with either library, or if it only happens with one.
OK, I'll not file a report unless you post that you have begun to have trouble again. I have not been able to reproduce the bug, using either library.
sometimes poser 2014 gets stuck on a search , it just says searching even after finding what ive asked it for , if i then click cancell it just stays cancelling forever 9well at least 2 hours as thats the longest ive left it) everything still works fine i can create stuff render save everything except searches once its stuck have all the updates .only way to stop is to close poser and restart any ideas?
