Fri, Nov 22, 10:59 PM CST
Subject: Poser 9 and Memory
Inspired_Art ( ) posted Tue, 22 October 2013 at 10:30 AM · edited Fri, 22 November 2024 at 7:24 PM
Will Poser 9 work with 512 mb ram?
Eddy
basicwiz ( ) posted Tue, 22 October 2013 at 10:45 AM
Not according to Smith Micro.
Even if it did, you would find it a nightmare of lags and crashes to try and use.
Inspired_Art ( ) posted Tue, 22 October 2013 at 11:06 AM
Probably wouldn't even start then eh?
Eddy
basicwiz ( ) posted Tue, 22 October 2013 at 11:15 AM
That would be my advice.
aRtBee ( ) posted Tue, 22 October 2013 at 3:48 PM
more in detail: you need room for the OS, background processes and other apps running. Then Poser will take another 300Mb, and rendering will take: 300Mb for the scene + 200Mb extra if the scene is quite detailed and very textured, plus 300Mb per (undressed) figure plus 200Mb per detailed / well textured clothing set. The "rendering  part" should not exceed 3Gb on a (boosted) 32bit system and/or on Poser 9 which is 32bit itself. So the Poser and the memory you need depends on your scenes.
512Mb will swap the OS to disk, load Poser, and will render just Android Andy in an empty scene. That's about it, though.
vilters ( ) posted Tue, 22 October 2013 at 5:28 PM
The smallest I tested it on was a 10" netbook, 1024x600screen,  single core, and 1GB RAM.
Stable but slow.
512? Is below min spec.
