Tue, Feb 11, 2:50 AM CST
Subject: Poser Python - Need Help Getting Started
TerriJohns ( ) posted Tue, 29 October 2013 at 1:33 PM · edited Tue, 11 February 2025 at 2:49 AM
I'm new to Poser Python. I am trying to perform a simple task - put a value into a figure's parameter (for example, bend the shin to a certain angle). But I keep getting an error message when I run my script. Can someone take a quick look and see if my syntax is incorrect?
My example:
import poser
import random
scene=poser.Scene()
scene.SetFrame(23)
scene.SelectFigure(scene.Figure('Roxie'))
actor = scene.Actor('Left Shin')
parm = actor.ParameterByCode(poser.ParmCodeBEND)
parm.SetValue(88)
When I run the above script, I get the following error:
Traceback (most recent call last):
*  File "C:UsersPublicDocumentsPoser Pro 2014 ContentMy Pythonkicking1.py", line 7, in *
*    parm = actor.ParameterByCode(poser.ParmCodeBEND)*
AttributeError: 'module' object has no attribute 'ParmCodeBEND'
Cage ( ) posted Tue, 29 October 2013 at 2:06 PM
I think you need to use a different parameter code.
kParmCodeXROT
kParmCodeYROT
kParmCodeZROT
TerriJohns ( ) posted Wed, 30 October 2013 at 9:47 AM
No dice, at least not yet. Altered the code to:
import poser
import random
scene=poser.Scene()
scene.SetFrame(23)
scene.SelectFigure(scene.Figure('Terri'))
parm = actor.ParameterByCode(poser.kParmCodeBEND)
parm.SetValue(88)
but got the error -
 in
AttributeError: 'module' object has no attribute 'kParmCodeBEND'
Aren't there some simple examples online? I've found a few sites claiming to be intros to Poser Python, but they are "Hello World" programs. I want to manipulate Poser, not figure out how to say "Hello World"  ;)
TerriJohns ( ) posted Wed, 30 October 2013 at 10:28 AM
My fault. Bend is not a valid code. YTRAN, ZTRAN and XTRAN are what I need to use. So the following code works -
import poser
import random
scene=poser.Scene()
scene.SetFrame(23)
MyFig = scene.Figure('Terri')
ChangeParm = MyFig.Actor("Left Shin").ParameterByCode(poser.kParmCodeYTRAN)
ChangeParm.SetValue(5)
I'm used to working with Bend values, so I just have to figure out appropriate YTRAN values instead. The next step is to add some randomness to the parameter changes to make movements look more natural.
stewer ( ) posted Wed, 30 October 2013 at 12:06 PM
Use the parm codes that Cage posted, those for rotation. YTRAN will translate the shin, not bend at the knee.
Cage ( ) posted Wed, 30 October 2013 at 2:51 PM · edited Wed, 30 October 2013 at 2:51 PM
In the folder where you poser.exe is installed, there should be a PoserPython Methods Manual.pdf, which lists all of the parameter codes near the top.  Each listing has a short explanation of what function the code invokes.  The list isn't necessarily the easiest to scan quickly, but it can be very helpful.  After a bit of trial and error, it's fairly easy to pick up the process, and you're doing well so far.  :thumbupboth:
TerriJohns ( ) posted Thu, 31 October 2013 at 8:14 AM
Thank you Cage. So a Bend, Side to Side, or Twist is accomplished by the various rotations. That's helpful, thank you very much.
You are correct, the PDF is not easy to scan. :)
timarender ( ) posted Thu, 31 October 2013 at 10:49 AM
Instead of "parm = actor.ParameterByCode(poser.ParmCodeBEND)", I suspect this might work:
parm = actor.Parameter("Bend")
icprncss2 ( ) posted Thu, 31 October 2013 at 2:42 PM
PhilC has a very comprehensive pdf on Python.  You might want to take a look at it over at PhilC.net.
Allstereo ( ) posted Thu, 31 October 2013 at 10:00 PM
Hello,
Here is the code that I used to get the value and set the value of a parameter
#Define the actor
actor = scene.Actor("External name")
#Read value of actor
actor.ParameterByCode(poser.kParmCodeYROT).Value()
#Set value of actor to 80
actor.ParameterByCode(poser.kParmCodeYROT).SetValue(80)
Allstereo
