Fri, Nov 22, 6:11 PM CST
Subject: Poser Pro 2012 Re-Building my Runtime - thoughts
Tracesl ( ) posted Fri, 08 November 2013 at 5:12 PM · edited Fri, 22 November 2024 at 6:05 PM
Well, my mother board took a dive and got a new PC, now in the process of putting back my runtimes, problem, have a lot of them and trying to think of the best way to handle them.  Running Poser Pro 2012.
Should I just keep them in on my backup drive?  Or should I move them all to the Poser Pro 2012 runtime?
Also, for some reason my Libraries are no lonber a sperate floating app.  Any thoughts?
Thank you.
LaurieA ( ) posted Fri, 08 November 2013 at 5:43 PM
External library requires Adobe Air (the embedded library uses Flash).
ironsoul ( ) posted Sat, 09 November 2013 at 5:38 AM · edited Sat, 09 November 2013 at 5:43 AM
Hi
Did you change the library preferences after the install?
Might be a good idea to keep a certain amount of seperation between the Poser runtime and your other content. The reason for this is that if/when you upgrade or reinstall Poser you do not need to be concerned about your 3rd party content being overwritten. Whether to keep the files on your backup drive or copy to the content to the PCs local drive will I guess depend on relative performance of the two disks.
Tracesl ( ) posted Sat, 09 November 2013 at 6:23 AM
got the library back - lost it after installling Photoshop so did re-install.
Now for the runtimes.
