Mon, Nov 25, 11:52 AM CST
Vue F.A.Q (Last Updated: 2024 Nov 21 4:12 am)
Subject: How to make an eco system stick to an object
iborg64 ( ) posted Wed, 20 November 2013 at 6:57 AM · edited Mon, 25 November 2024 at 11:26 AM
I am trying to find a way to make an eco system stick to an object , for instances ivy on a wall . The eco system painter paints on the wall but how can i make it part of the wall ? At the moment it looks like its on the wall untill i repostion the wall then it leaves the ivy behind. There dosnt seem to be an option to group the wall and the Ivy as one object (at least not that I can see) i am using vue 10 xstream
bruno021 ( ) posted Wed, 20 November 2013 at 9:04 AM
You need to check the "Restrict to underlying object" top icon (4th from the left) of the EcoPainter dialog, then brush away. The eco material will stick to the object if you move it.
iborg64 ( ) posted Wed, 20 November 2013 at 10:30 AM
Ah  I see many thanks for that very helpfull
bruno021 ( ) posted Wed, 20 November 2013 at 11:53 AM
Forgot to add that this option is not available by default in the painter, you need to create a material ecosystem first, then click on Paint to open the ecopainter with this option already enabled.
