Community Center F.A.Q (Last Updated: 2024 Nov 22 2:37 am)
the TOP rarely changes ..it has being like that for many many many years ..
And that only changes when some one removes its FB or some one makes a killer item that gets a zillion downloads ..
but the counting does work fine.
Chris
Errr...I beg to differ, but no it doesn't - at least not on my system.
The screenshot in the OP was the top end of the "Recent Top 50" from 19th November (a week ago). Compare it to the attached screenshot from today (27th). Then go and check the recent top 10 for yourself just to be sure. Same applies for the whole recent top 50 and all-time top 50 - nothings changed (and I'm specifically referring to the numbers) in the past month.
P.S. The download counts for individual freestuff items appear to be working fine - it's just these totals that have frozen. As I said,a mere trifle...
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
Just another gentle nudge to make sure this doesn't drop off the bottom of the 'to do' list ;o)
(Yes, the numbers are still exactly the same as two months ago)
http://www.renderosity.com/mod/freestuff/top_contributors.php
I know this is just a trifling little thing, but if you let lots of trifles pile up, you know where you end up... blancmangeageddon !
