Sun, Jan 26, 3:47 PM CST
Subject: Making Belts
Bristow13 ( ) posted Mon, 24 September 2001 at 2:02 PM ยท edited Thu, 01 August 2024 at 3:10 PM
Ok i took this picture from the Asylum but i need help, i guess you make the belts of photoshop or PSP7 am i right, well if not tell me. But how have they used it here when its not a prop, did they cut it out or have the done something else please could help me out.
Crescent ( ) posted Mon, 24 September 2001 at 5:02 PM
If you have a modelling program like Rhino, you can make belts yourself and import them into Poser. Otherwise, you need to do them in post-production.
whitemexican ( ) posted Mon, 24 September 2001 at 6:13 PM
not entirely true there is a very easy way to make belts like in the above picture. Simply take a shirt texture and make a trans map in the shape of the belt how you want it to go and then save it as belttrans, then in the outlines make the belt save it as belt. Now go into poser and create a new figure with a male t-shirt go into the materials and load the belt for the texture and belttrans for the tansparnecy map. Make sure the trans min, max and fall-off are at 100 and then when you go back you'll notice that the shirt is now a bunch of dots. Render the picture and the shirt will be gone and the belt will be there. Simply conform the shirt to the body and the belt is around him. This trick will work for anything to be put on a figure, wrist bands, elbow pads, chains whatever you need.
praxis22 ( ) posted Tue, 25 September 2001 at 11:13 AM
Attached Link: http://www.billy-factory.com
Talk to BillY-T he's got a couple of them on his site. later jb
