Sat, Feb 8, 10:48 AM CST
Subject: Christmas 2013 Freebie - Jessi 1 Improved
Lyrra ( ) posted Sat, 14 December 2013 at 1:42 AM · edited Sun, 22 December 2024 at 2:19 AM
For my christmas present to the community this year I decided to fix somethign thats been bugging me for a while.  Jessi 1, (not Jessi g2) has a certain athletic appeal, but some terrible bend distortions make the figure frustrating to use.
So .. I decided to fix that.  After making several dozen bend fixing morphs, I made a 'few' full body morphs .. and then some more .. and some partial morphs .. and some scaling dials ... and some fixit morphs for the strang skull shape and jaw and ....
So here is Jessi 1 improved. If you have version 6 or above of poser you should have Jessi in there somplace and be able to use this figure.
Thanks to SnarlyGribbly and Baggins Bill for the lovely EZskin settings applied over jessi's stock maps.  Thanks to my poor much beleagured beta testers - SsgBryan, Geep and Villters
A set of morphs - bend fixes, fullbody shapes, head shapes, head fixes and scaling morphs to add more useability and flexibility to the jessi1 figure.  Promos shown with the Jessi1 mterials supplemented by ESkin settings.
Usage Tips and Limitations: this uses the regular jessi1.obz based figure NOT the 'hires'.  The Cr2 contains many morphs. Some scaling morphs may only work properly in poser 9 and 10. Bend fix morphs must be manually applied
Cr2 contains skin settings from EZskin2 by SnarlyGribbly, with his permission. Maps required are the stock maps from poser with no edits.
A number of head morphs were created using the dials hidden away in the Face room. Some were slightly modified via smoothing to be more useable. They are by no means perfect and you will have to fiddle. However they do add a range of options that were previously missing, so have fun messing about
Body morphs fall into the following groups
Spandex - these morphs are best used with SecondSkins, the smooth and remove features for the appearence of a bodysuit with no clothing mesh
FullBody - these morphs chape the entire body of the figure excepting hands, feet and head
Partial Body - These morphs change smaller sections of the body and are roughly grouped by region
Bendfixes - These morphs fix mesh crumpling caused by bending parts. They are roughly grouped by region and named by bodypart name, direction and degree of bend.
Headfixes - these three morphs have been left on and change the appearence of the head
Scaling - these morphs effect only the scaling dials on the figure and can be used to alter the bodypropertions
http://www.sharecg.com/v/73646/view/11/Poser/Jessi-1-Improved
Link to ShareCG
Poser Freestuff link should pop up in the next few days
Happy Holidays,
Lyrra Madril
ironsoul ( ) posted Sat, 14 December 2013 at 5:08 AM
Many thanks Lyrra, I 've often thought she needed morph options to give her a less "dramatic" shape. Only just started looking at them but looks an excellent set.
As feedback (not complaint) I'm getting "The file has newer version number than expected" message when loading in pp2012. Just appears to be a warning as figure and morphs load ok - I'm probably doing something wrong but if you think its something more fundamental and need more info let me know.
EClark1894 ( ) posted Sat, 14 December 2013 at 5:27 AM
Thanks Lyrra. I just wish she was weightmapped. I always like Jessi except for that big Sade-looking forehead of hers.
Lyrra ( ) posted Sat, 14 December 2013 at 5:37 AM
Ironsoul
the file was saved in pp2014. older versions of poser will whine, but load it anyays.  the only thing that may not work pre-poser 8 or so is the scaling morph dials
EClark
well a wm version would mean conversion of all the clothing .. this at least has the benefit of backwards compatability. A little morph transfer and voila, the old wardrobe( all 8 things) is ready to go.
Try it with subdivision on .. it looks pretty darned good for an older lady :)
Lyrra
Lyrra ( ) posted Sat, 14 December 2013 at 5:39 AM
another promo image
foxylady1 ( ) posted Sat, 14 December 2013 at 5:47 AM
She looks great, thank you very much.
hborre ( ) posted Sat, 14 December 2013 at 6:26 AM
Thank you.  I look forwards to trying her out.  If you are using PP2014, then you can applying weight mapping within the program.  Interested to see if this enhances the applied fixes.  Thanks again.
Lyrra ( ) posted Sat, 14 December 2013 at 7:03 AM
adding weightmapping would do very little, unless you then adjust the weightmaps. but then you have to deal with all the clothing ...
Just use the subdivision instead. quick, easy, and less headaches getting thngs to work
LM
infinity10 ( ) posted Sat, 14 December 2013 at 7:29 AM
Many thanks for this.
Eternal Hobbyist
NanetteTredoux ( ) posted Sat, 14 December 2013 at 7:34 AM
Thank you for this thoughtful initiative and all the work you put into it.
Poser 11 Pro, Windows 10
jonnybode ( ) posted Sat, 14 December 2013 at 8:08 AM
Most kind of you, thanks!
Tunesy ( ) posted Sat, 14 December 2013 at 8:15 AM
Beautiful work, Lyrra.  I always thought Jessi had a pleasant shape but now she's a lot more usable.  Thanks so much for making it available as a freebie.  You obviously put a lot of time in to this.
WandW ( ) posted Sat, 14 December 2013 at 10:07 AM
Quote - adding weightmapping would do very little, unless you then adjust the weightmaps. but then you have to deal with all the clothing ...
As long as the grouping doesn't change, it's nothing that 'Copy Joint Zones From' or Poser Place's Outfitter  (free at RDNA) couldn't handle.
Thanx for this Lyrra!  😄
Lyrra ( ) posted Sat, 14 December 2013 at 11:36 AM
Rosity freestuff link ... that was fast
http://www.renderosity.com/mod/freestuff/details.php?item_id=72974
MikeMoss ( ) posted Sat, 14 December 2013 at 1:21 PM
Hi
Thanks: I use the Jessi 1 figure all the time, I'll check this out.
Since my Lucy character is based on Jessi and I haven't had any luck trying to redo her and have her look the same in a latter version this is a welcome improvement.
Mike
If you shoot a mime, do you need a silencer?
Alisa ( ) posted Sun, 15 December 2013 at 1:24 PM
Thanks, Lyrra :)
Cheers,
Alisa
RETIRED HiveWire 3D QAV Director
EnglishBob ( ) posted Mon, 16 December 2013 at 4:24 AM
Online Now!
Interesting project - thanks for your effort!
bzzenk ( ) posted Tue, 17 December 2013 at 3:38 PM
Attached Link: Jessi P6 dances
Thank you very much for this work on Jessi - FANTASTIC ! This new and improved version has inspired me to create another Jessi Dance Animation. This is what I wanted for Christmas 2013 - THANKS THANKS THANKS ! ! ! ! !
