Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 7:14 pm)
Quote - so rolled back to 10..it now works.... is there goingt o be a patch so P9 works with ie11 ???
It's here...
http://poser.smithmicro.com/poser9-updates.html
"Oh - the manual says that? I have never read the manual - this must be why."For some reason there is not a patch to fix PP2012 yet. You could try using the external library if you don't want to roll back to IE10 (EDIT Since Poser is crashing, you need to edit Poser.ini to use it; set LIBRARY_IS_AIR 1). If you do roll back, MS has a download to prevent IE 11 from being automatically reinstalled...
http://www.microsoft.com/en-us/download/details.aspx?id=40722
"Oh - the manual says that? I have never read the manual - this must be why."Quote - For some reason there is not a patch to fix PP2012 yet. You could try using the external library if you don't want to roll back to IE10 (EDIT Since Poser is crashing, you need to edit Poser.ini to use it; set LIBRARY_IS_AIR 1). If you do roll back, MS has a download to prevent IE 11 from being automatically reinstalled...
That also sometimes works so for Poser on Linux with wine when flash will not work or interact with the Poser library there. :) Finding "LIBRARY_IS_AIR 0" in the Poser.ini and changing it to "LIBRARY_IS_AIR 1" with a text editor is both Windows and Linux awesomesauce. XD
My brain is just a toy box filled with weird things
Ok, so MicroSuck forced IE11 on my system. How do i roll back without throwing my computer off a cliff? I just bought a bunch of items I'd like to play with in PoserPro2014. We really need a Linux version of Poser, or gulp, I'll convert to Mac...-Starkdog
P.S. I cannot find Poser.ini file, so where is it hiding, or did IE11 kill that too?
decided to load up Poser this morning, and it will not load..gets an error message ..Poser executable stopped working, during the screen app screen load.
any ideas? it has worked flwlessly since it was installed. Last program i installed was PSP X6 couple of weeks ago, and this is the first time Poser has not worked .... maybe it messed up a file or something.
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
