Wed, Jan 8, 8:28 PM CST
Subject: Emitter Primitive
FoulPet ( ) posted Sun, 15 December 2013 at 9:42 PM · edited Wed, 08 January 2025 at 8:07 PM
 I've read 3 different post on this and have played with the settings several ways. I am trying to have a primitive give off light.  I can get the primitive to illuminate when all lights are out but, I can not get the primitive to give off enough light to illuminate another object.   What am I doing wrong?  I have linked a pic. Thanks
settings
WandW ( ) posted Sun, 15 December 2013 at 9:52 PM
Do you have IDL enabled in your render settings?
Miss Nancy ( ) posted Mon, 16 December 2013 at 2:04 PM
with IDL/raytracing enabled, using ambient=6 may cause the sphere's surface colour to burn out in FFRender.
Winterclaw ( ) posted Mon, 16 December 2013 at 4:50 PM
What those two said.  Location also helps.  I can't tell if the object is in front of, beside, or behind the skeleton and that's going to affect things.  If it is a 2d plane, than I assume that could cause issues as well.
Also, if you don't know how to use render settings go to Scripts > Partners > Dimension3D > Render firefly and change it from there.  The default one doesn't have as many options.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
hborre ( ) posted Mon, 16 December 2013 at 7:34 PM
This is perhaps the affect you are looking to achieve.  A simply Hires ball floating just before the M3 Skeleton.  All lights were deleted from the scene and the ball given an orange color with an ambiance value of 2.
hborre ( ) posted Mon, 16 December 2013 at 7:39 PM · edited Mon, 16 December 2013 at 7:39 PM
The Mat Room PoserSurface for the Ball.  Again, a simple arrangement, diffuse_ and specular_colors set to black and their respective values set to 0.  Only the Ambient_Color chip has been changed to orange and it's Ambient_Value set to 2 to prevent the glow from blowing out.  The Reflection_Lite_Mult is unchecked.
hborre ( ) posted Mon, 16 December 2013 at 7:45 PM · edited Mon, 16 December 2013 at 7:45 PM
The scene was rendered with IDL enabled over black background.  As Miss Nancy points out, Ambient_Value of 6 will lead to burnout; that is why I chose to go with 2.  And as per Winterclaw's suggestion, I am posting D3D's Firefly Render script to give you an idea of some basic settings.
Winterclaw ( ) posted Mon, 16 December 2013 at 11:43 PM
I hate to ask this, but what does precalculation scale do?  I've done a few test renders but I can't seem to figure out what it is for.
WARK!
JoePublic ( ) posted Tue, 17 December 2013 at 12:03 AM
The problem with hborre's setup is that an ambient value of >1 will change the color of the emitter prop. In this case, the orb looks yellow while it casts an orange glow.
So for my render I used a second orb, slightly bigger than the first one.
The first one has an ambient value of 5, but is made invisible to the camera, so only its "glow" is visible in the final render.
The second one has an ambient value of 1 and is not visible in raytrace, but in camera.
So it just renders normally, but doesn't block the glow of the first orb hidden inside it.
This way, the orb glows red while it still "looks" red at the same time.
Winterclaw ( ) posted Tue, 17 December 2013 at 12:13 AM
While I'm thinking about it, how do you get your renders to not turn out grainy with IDL?  That's a problem I've been fighting with forever.  Increasing the number of sampes helps, but it's still there for me.
WARK!
Winterclaw ( ) posted Tue, 17 December 2013 at 12:19 AM
This is pretty normal for me and one of the big reasons I don't use IDL as much as I want to.
WARK!
hborre ( ) posted Tue, 17 December 2013 at 8:46 AM
Precalculation scale just scales down the image and quickens precal in IDL pass.  Rather than staring at your final render full scene, it's reduced to a fraction of the viewing area.
@ JoePublic:  Good observation.  I did it as a quickie and chose 2 to brighten the render for posting.  I like your recommendation.  Must give it a try.  Thanks.
Winterclaw ( ) posted Tue, 17 December 2013 at 12:31 PM
Okay, so it sounds like something you can turn down for test renders.  Thanks.
WARK!
Miss Nancy ( ) posted Tue, 17 December 2013 at 1:10 PM · edited Tue, 17 December 2013 at 1:10 PM
 wint, to ameliorate graininess, {incr. pixel samples, decr. shading rate, turn off IDL IC, incr. IDL samples} all to the maximum extent possible within time constraints avail. for render.
Winterclaw ( ) posted Tue, 17 December 2013 at 4:12 PM
Thank you nancy, it was actually the IDL's irridance cache that was giving me problems.  I usually had it on 100 because I thought doing it all at once would be better.  Turns out not.
Turns out it looks best on 99 with a seperate pass and not on 100 for some reason.
WARK!
FoulPet ( ) posted Tue, 17 December 2013 at 8:06 PM
WoW  thanks for all the Help.  I'll give it a shot and see what happens.
FoulPet ( ) posted Tue, 17 December 2013 at 8:43 PM
See no way to edit pre-post ...  I had IDL off :p  Thanks for all the help.  I wanted to experiment with making fluorecent tubes.
bagginsbill ( ) posted Tue, 17 December 2013 at 10:11 PM
Setting the irradiance cache to 100% means don't use it. It means you want 100% accurate lighting, not interpolated at all via IC. Unfortunately, without interpolation (which smooths the variations) you get visible grain from the local per-pixel inaccuracy when you don't use enough samples to converge on the correct (and therefore consistent) value.
Winterclaw ( ) posted Tue, 17 December 2013 at 11:14 PM
Bill, I really wish the manual would say stuff like that.  What you said makes a lot sense from what I can understand, but it's also counter-intuitive.  Most people (myself included because I was lazy) would think that 100% should produce better results than 99% because "how is this working on the inside isn't a question" a lot of people start with.
I'll be honest, until Nancy mentioned it, it was one of the few render settings I didn't tinker with.  I was looking to other places to try and find out the cause and it never occured to me to turn down the cache.
I was making a bad assumption because in a lot of cases, lowering a cache tends to hurts results.  So at least I know now that this one setting probably needs to be a little bit in the middle because I don't want to run 2k samples all the time.
All this not knowing what's happening under the hood has really been killing me in using poser and was an obstacle.  So I'm grateful for learning more.  The other day in chat for example, someone finally helped me with my mat room problem (when even SM's tech support couldn't, I tried it once).  Turns out leaving that Poser Surface preview on was what was causing all the lag I was seeing.
I guess I'll just have to learn when to start turning things off or turn them down.
WARK!
seachnasaigh ( ) posted Wed, 18 December 2013 at 5:00 PM · edited Wed, 18 December 2013 at 5:03 PM
     Try **edit:duplicate** to make another sphere.  Scale that one a little bigger so that the two spheres don't have polygons sharing the same space.  Parent it to the first sphere.
     For the first sphere, give it a gentle ambient, about 0.5 to 0.75 or so.  High ambient will both white the ball out (except for primary colors - yours is apparently pure red) and make it lose depth (note that yours appears to be a flat silhouette).
     The second (slightly larger) sphere can have a high ambient.  Try a fairly rich but not pure red.  This sphere will be your unseen IDL emitter.  The trick is to set the properties of this sphere to not cast shadows and to not be visible in camera. See attached screen shot.
     Render with IDL enabled.
seachnasaigh ( ) posted Wed, 18 December 2013 at 5:02 PM
     Here is a starting point for render settings.  Increasing irradiance cache and pixel samples will improve the lighting, at the cost of memory usage and render time.
seachnasaigh ( ) posted Wed, 18 December 2013 at 5:04 PM · edited Wed, 18 December 2013 at 5:05 PM
*Et voila!*
