Thu, Feb 27, 6:53 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 3:55 am)
Subject: Aiko4's body doesn't load properly in Poser 9
Naneth36 ( ) posted Thu, 02 January 2014 at 11:57 AM · edited Thu, 27 February 2025 at 3:44 AM
Hello everybody,
I've got a problem. I recently bought Aiko4 and Hiro4, and as my Poser 9 turns on a 64 bits computer, I took the .zip files and installed all the files manually.
Hiro4 works fine.
But when I download Aiko4 as a full character, only her head "reacts". She keeps V4's body and eyes shapes. Same thing when I inject her morphs in a V4.2 base.
Thanks for your help.
JimTS ( ) posted Thu, 02 January 2014 at 12:23 PM
In the !DAZ folder in your runtime/libraries you will find a file DzCreateExPFiles-V4.bat run it then try
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
 Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
Naneth36 ( ) posted Thu, 02 January 2014 at 12:41 PM
:thumbupboth: YES, IT WORKS !!! :thumbupboth:
:biggrin: :biggrin:Thank you so much, JimTS !!! You saved my day !!:biggrin: :biggrin:
hborre ( ) posted Thu, 02 January 2014 at 3:36 PM
Every time you add a morph package, you must run the bat file afterwards.
RHaseltine ( ) posted Thu, 02 January 2014 at 3:58 PM
Why does using a 64 bit computer mean you have to install manually? The DAZ Install Manager runs on 64 bit systems - 32 bit software does, otherwise you wouldn't be able to use Poser 9.
JimTS ( ) posted Thu, 02 January 2014 at 9:39 PM
Quote - Why does using a 64 bit computer mean you have to install manually? The DAZ Install Manager runs on 64 bit systems - 32 bit software does, otherwise you wouldn't be able to use Poser 9.
Why would you bother with an installer designed to service DS4.xxxx?
Charles Péguy
jestmart ( ) posted Fri, 03 January 2014 at 10:30 AM
DIM is in no way connected to DAZ Studio.  The only flaw with DIM is it installs CMS and I have compalined about this to DAZ customer service.
