Great dynamics in that animation!
"Oh - the manual says that? I have never read the manual - this must be why."Quote - How some of you remember everything that's in the manual astounds me, but I'm grateful that you do. Thank you!
I'm re-rendering all three of my current sequences now. I'll let you know how it's going in a couple of weeks . . .
I only remember things that I have to deal with more than once, or that I see come up more than once. There are several instances each day that I will open it and check on something.
Attached Link: Ceremonies and Celebrations Promo
> Quote - Great dynamics in that animation!
Thank you! This is my second fully animated effort. You can see the first one here in the attached link. I'm trying a lot of things this time around that are REALLY pushing the envelope of my skills.
Firefly (and other renderers as well) introduces some noise-based mechanisms to get better results fasters. IDL, AntiAliasing, MIP-mapping (in handling texture patters) are examples of this. The noise generator starts the same way for each frame, but that start seems to be CPU/thread dependant in some way or another.
As a result, the recommended way of rendering animations is to do so single-threaded. No multi-processing, no network rendering, just the same thread each fame. This is the recommendation from the manual.
Which - of course - is exactly what one does not want to do when rendering animations :-).
Otherwise, the animation will show flickering. In the light (IDL issue), at the edges (AA issue) or in patterned textures (MIP issue).
I'm not a video-processing expert, but perhaps there are some de-flicker and/or de-noise modules avaliable in the video software. Google suggests NeatVideo for Premiere of some build-in denoising in After Effecs. Then one can render at full speed, and correct for the artefacts later in the flow.
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
It's interesting that you've written this. I'm noticing that the light doesn't look nearly as realistic without IDL thus far. The reason I'd been rendering each of the frames at high quality was an effort to create animated snippets that required less post-processing.
I use AVIDEMUX to put the frames together. It usually works well. Premier has a confusing interface, and unless someone actually showed me how to do what I need to do, the degree of frustration I experience with Adobe products in general motivates me to avoid using them.
So I'm a bit disappointed in the rendering process thus far. It just doesn't have the look I was seeking.
Try adding an IBL. There are some included in Poser, in the Library under Lights>Image Based Lighting. I'd try the Interior Light...
EDIT; here's a BagginsBill creation that can create an IBL map from your Poser scent itself. Theoretically there is no difference between an image rendered with such an IBL and one using IDL...
https://sites.google.com/site/bagginsbill/free-stuff/genibl---ibl-generator
"Oh - the manual says that? I have never read the manual - this must be why."I missed that you were already using an IBL, as usually an IBL is not used with IDL...
"Oh - the manual says that? I have never read the manual - this must be why."Usually when IBL is used with with IDL it's outdoors to replace the skydome; I thought the render was indoors. However, this doesn't have anything to do with the flickering...
"Oh - the manual says that? I have never read the manual - this must be why."Thinking about it, the likely reason it doesn't look as good with IDL off is that IDL provides AO; is AO turned on for your IBL?
"Oh - the manual says that? I have never read the manual - this must be why."Attached Link: GI render test
Hi the problem you describe is a long standing one seen in animations rendered with indirect, lighting even with the expensive "high end" render engines.
I rendered a *short video over a year ago explaining the technical reason why this happens, while also testing a flicker free setting in a GI animation render using Maxon Cinema4D
** click the HD button on the lower right if you want to see the clip in Hi def*
https://vimeo.com/44397428
Cheers
Attached Link: Cynthia Fantasy Dream Sequence Video Draft
This is my latest vexation. I'm working on a new animation project, of which the linked video is a draft. (She's holding a rose in the final version.) At the very end of this clip, if you pay attention to Cynthia's neck you can see flickering shadows. I don't know why Poser is doing this, but it's fairly consistent in every version of this particular animation snippet that I've created, and also appears in a differnt one I'm rendering right now.I have gone through every parameter of every light to make SURE nothing changes beyond frame 15. I am using no Ambient Occlusion, either. There are three lights in this scene, one infinite, one IBL and a spot light for "fill." I only have shadows on for the infinite light.
Does anyone have any idea why I'm getting this odd flickering?
