Fri, Nov 22, 10:24 PM CST
Subject: Breasts
Inspired_Art ( ) posted Sat, 01 February 2014 at 9:45 PM · edited Fri, 22 November 2024 at 10:07 PM
Now that I've got your attention....
Having no experience with the female body or their clothes :P I am wondering if the render below shows that the dress top is a close enough fit for the shape of the breasts? Should the circled area drape across the breasts? Should I use magnets? Etc...
Eddy
hborre ( ) posted Sat, 01 February 2014 at 9:55 PM
With Poser 10/PP2014, you can use the morph brush to tighten the mesh around that area.
But which version are you using?
Inspired_Art ( ) posted Sat, 01 February 2014 at 10:07 PM
PP2012
Eddy
hborre ( ) posted Sat, 01 February 2014 at 10:17 PM
Although PP2012 doesn't have the improved features found in the latest, the morphing brush would be the better approach to improve the problem.  PP2012 morph brush can transform across body parts better than previous versions.
NanetteTredoux ( ) posted Sun, 02 February 2014 at 1:09 PM
Just make sure you use the PP2012 morph brush at a very low intensity. As PhilC puts it, it tends to be a bit aggressive.
Poser 11 Pro, Windows 10
MistyLaraCarrara ( ) posted Sun, 02 February 2014 at 1:49 PM · edited Sun, 02 February 2014 at 1:50 PM
many of the breasts shapes and movement are magnet based.
i spawned them into morphs and then use Morphing Clothes to add the morphs to the clothes.  iz how i fit for gorgonzuella lol bit extreme
Inspired_Art ( ) posted Sun, 02 February 2014 at 1:49 PM
Thanks Guys!
Eddy
Sharkbytes-BamaScans ( ) posted Thu, 06 February 2014 at 10:27 AM
How about making either an FBM or a PBM of the chest area and then transferring that morph to the clothes?  I've had better results with that kind of work flow than I have with WW or anything else.  Even the fitting room makes clothes explode on me.  WW I just haven't been able to get a handle on and nothing PhilC seems to write or explain makes me get it any better.
Inspired_Art ( ) posted Thu, 06 February 2014 at 6:06 PM
That's an option right there. Thanks Sharkbytes~!
Eddy
