messing with post filter size didn't work. So What I did was doubled the render size and lowered all the render settings. 5 min render and the z-depth map is a lot cleaner. bring it into photoshop and reduce its size and much better result!
Quote - I charge the z-depth map as selection in PS (copy z-depth map , go to the image layer , select quick mask mode and paste ) and then perfected the edge as I desire ("Refine Edge" I think it's the command in English) , works perfect for me
Sounds good.Ill lok into that too. I'm using CS5
My
self-build system - Vista 64 on a Kingston 240GB SSD,
Asus P5Q
Pro MB, Quad
6600 CPU, 8 Gb Geil Black Dragon Ram, CoolerMaster HAF932 full
tower chassis, EVGA Geforce GTX 750Ti Superclocked 2 Gb,
Coolermaster V8 CPU aircooler, Enermax 600W Modular PSU, 240Gb SSD,
2Tb HDD storage, 28" LCD monitor, and more red LEDs than a grown
man really
needs.....I built it in 2008 and can't afford a new one,
yet.....!
My
Software - Poser Pro 2012, Photoshop, Bryce 6 and
Borderlands......"Catch a
r--i---d-----e-----!"
Quote - There's a very good Python script at RDNA called "Advanced Render Settings" by Semideu. It produces a ZDepth render which is far superior to the native Poser one in that it is antialiased and can also handle transparent texture maps. The ZDepth render is in fact only one tiny aspect of this plugin, it will revolutionise the way you use Poser - get it, you won't be disapointed and if you make a lot of use of ZDepth renders it's indispensible. I use it every day, the best $19.99 I ever spent for my CG work.
That sounds great! I will check it out. Thank you!
nasty jaggys from z-depth map ruining my photoshop lens blur. Any thoughts on a trick to fix this other than running the map through gaussian blur beforehand?
